Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Dec 2009
    Quote Originally Posted by ccan View Post
    Okay thank you. perhaps calls lang talaga pwede maintegrate dun. thank you for explaining further :-)
    The BT is purely useful for audio streaming
    USB is for reading music files or power supply
    HDMi is for any hdmi device like a digital tuner or mirroring (streaming screen image via wifi) device. a google chrome or miracast device, get the device that is compatible to your smartphone. Attach it to the hdmi port of your headunit. Configure your wifi hotspot and make the proper settings to connect the smartphone and the mirroring accessory into the hotspot and youre good to go. Theres no need to buy a high end head unit
    If the stock unit has an ip configuration already then theres no need to get a mirroring accessory
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Apr 2017
    Hello. the stock head unit of toyota vios 2015 is mirrorlink ready meaning you can use the head unit as a display from your smartphone. You can also use the display to navigate your smartphone. I hope this helps.
    Cheers
2015 Toyota Vios Touchscreen headunit
