Results 21 to 30 of 40
Threaded View
  1. #1
    Join Date
    Dec 2007
    Thumbs up Avanza DIY: Replacing Headlights
    Here's how to replace our beloved ride's headlights...
    You'll need the following:
    • Replacement H4 bulbs
    • Two fingers, preferably thumb and index finger
    • Good lighting (daylight or flashlight
    • Courage
    • A little strength
    Let's begin the walkthrough for one (1) headlight...
    1. Pop the hood.
    2. Locate the back portion of the headlight. Identify the modular plug:
    3. Remove the modular plug (just pull it out gently, moving it a little bit from side to side):
    4. Locate the protruding rubber so you can use it to pull off the rubber cap/cover (my index finger is touching it here):
    To be continued...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
