Page 52 of 68 FirstFirst ... 24248495051525354555662 ... LastLast
Results 511 to 520 of 680
    Aug 2012
    #511
    According to Mike Philips of Meguiars USA, there is no need for "special" product for ceramic coating. All their products can work.
    If you think of coating as a second layer of clear coat, then any detailing product that is safe for your car paint is also safe for coating.
    Sent from my ASUS_X00DDA using Tapatalk
    Nov 2017
    #512
    Quote Originally Posted by red_one View Post
    That's good to hear! I do have Meguiar's Ultimate Quick Wax, I can perhaps use that as an extra protection for the ceramic coating. As mentioned from another post in this thread, Meguiar's Ultimate Quik Detailing can be used for removing those nasty water spots and other contaminants. All of these products are conveniently available at local stores.
    Nov 2017
    #513
    Quote Originally Posted by zechs View Post
    *jojopad,
    You have reseller of carpro products in olx, not sure if their line is extensive though.
    Another alternative brand is Gyeon which has a reseller here down south.
    Thanks Zechs for the info! I'll check out your suggestion.
    Aug 2012
    #514
    One of the purpose of ceramic coating and any other paint coating is so that you don't need to wax the car anymore.
    Nov 2017
    #515
    Waxing is optional, at least that was the tip from a detailing shop I went to. I reckon it can provide extra protection especially on areas prone to road grime, prolonging the ceramic coating.
    quik wax? it probably wipes off easily [emoji848]
    Nov 2017
    #517
    I used it for another car for the past month. So far it lasted for a month. Not bad for a spray wax that's very convenient to use.
    Nov 2017
    #518
    *jojopad,
    Found this local distributor of CarPro products from CarPro | CarPro Distributors | CarPro Car Care Products
    CarPro PH
    Aug 2009
    #519
    What remedy do they apply to coated cars that have hairline scratches?
    Sent from my ASUS_Z00ED using Tsikot Forums mobile app
    Aug 2009
    #520
    Quote Originally Posted by Calistro View Post
    Answering my own query; Remove coating, treat as you would normally, apply back coating
Inputs needed: Glass Coating
