Originally Posted by
madkatz
SwirlX could be used by hand, but there have been a lot of different reviews about the results obtained via hand application, machine application however produces uniformed and better results but again it does not mean that the same results cannot be achieved by hand, hand application of swirlX or any SMR's are totally dependent on application method, so if you could dial in on one system or style of hand application that you like you could do that to the rest of the vehicle, and as we've said if its by hand application we usually recommend going from the least to more aggressive method.
Another alternative you could do is use 2x coating of Nano Glos to cover up the swirls before you apply 476, this way you fill in the swirls so its visually removed and the filling Nano Glos has, has a better durability compared to glazes so its stays there longer and can last more washes.
The steps you mentioned is correct
Carlack Long Life Sealant is a good sealant to be combined with 476, however you still get the maximum results of the sealant if you use the Carlack NSC to prep the paint to let it accept Carlack LLS properly, and then layering 476 after 24 hours is a great idea if gives you two of the best and most durable protection available from waxes and sealants
My BF used to sell them in smaller repackaged quantities but i think he already stopped, try calling Big Berts i think they still have Carlack available.
Tesla Philippines
