Results 1 to 10 of 1650
- Aug 2009
- 1,553
July 22nd, 2010 01:30 AM #1im with kafph's answer, that would really be a problem to the paint if you don't address it, as for the solution i really can't say because i haven't seen it, maybe take a shot of the aircon and parking space and post it here, who knows someone might actually come up with a nice plan for your problem
MODERATOR's NOTE:
Original archived thread can be found here:
http://tsikot.yehey.com/forums/showt...18901&page=394Last edited by ghosthunter; July 26th, 2010 at 05:39 PM.
- Aug 2009
- 1,553
July 22nd, 2010 01:32 AM #2hmmm thats odd, stains from 3m liquid... regarding the double wax removing the stains, if the stains are above the paint then there's a high chance it would be removed but i still don't see why it would stain, better bring it over to BB to have it check if thats the case, or posting pictures could help
- Jun 2010
- 61
July 22nd, 2010 11:14 AM #3
July 22nd, 2010 03:11 PM #4
LATEST UPDATE.......
ONLY 6 CARS will be used...
WASH & LEARN (6 SLOTS ONLY)
1) psi
2) jmpet626
3) Chikselog
4)
5)
6)
WATCH & LEARN
1) azzkkr2600 -- tentative
2)
3)
4)
- Jul 2010
- 169
July 22nd, 2010 04:47 PM #6binasa ko ulit mga tanong ko at sagot nyo.. ang kulit ko pala sobra haha.. pasensya na at salamat sa pag sagot sa mababaw na tanong ko.. totally wala talaga kasi ako alam eh.. saka naguguluhan ako sa step 1 2 and 3 tapos may susulpot na mga pamatay na compound na step 1 din pala sila.. na step 1 na din naman yung mga cleaner wax / paint cleaner.. pero it depends pala sa case ng auto mo kung ano tatawagin mong step1 2 and 3.. salamat dami ko natutunan.. matatag na foundation ko hehe sana tumatag pa lalo.. masyado lang ako nag mamadali matutunan ang pag dedetail ang saya kasi eh.. :chopper:
ok lang ba gamitin parehas sabay ang OGE at Sliq? tanong lang sino dapat mauna? nasa isip ko si sliq kasi si OGE nag rerepel ng kung ano ano .. pero syempre need ko ng knowldge ng mga gurus ...
masaya kahit overkill basta sure na mag bobond sila kahit 6 layers na wahaha
- Jul 2010
- 169
July 23rd, 2010 07:56 PM #7mga ka-adik may tanong ako.. nasa page 242 palang ako sorry kung natanong na to sa iba pang pages.. may nabasa ako na QD's are for looks lang and pag need ng protection i should use spray wax..
question: i'm using nanoSliQ,thinking na QD siya.. this is how i apply my SliQ.. spray spray tulo wipe.. next panel spray spray tulo wipe, .next.. and so on.
after ko ma spray and wipe ang buong kotse.. may moist na naiiwan ang nanoSliQ.. parang liquid wax or paste wax.. then i-bubuff ko na siya para shiny na.. ang tigas na parang wax talaga.. ang tanong spray wax ba ang nano Sliq?
*para sakin ok lang iwan ko ng matagal ang wax kahit mahirap na tangalin..atleast i'm sure na kapit siya talaga haha pang palaki pa ng muscles haha.. although sabi sa container after 15min i-buff na dapat.
(if may mali sa steps ko lalo na yung hinahayaan ko patigasin/longer curing time,.. paki sabi lang po yung tamang way.pros and cons ng ginagawa ko.)
July 23rd, 2010 11:13 PM #8
Di na kailangan iwan ng matagal ang wax, maximum 15mins tapos buff off na agad.
Hehe I'm telling you now don't dare do that to a Collinite especially 476S at lalo na ang Fleet, you'll faint trying to buff it off, seriously. And you might scratch the paint trying to buff the dried wax.
Iisa lang ang kapit nyan kahit 1 taon mo iwan yan or 1 week or 1 day. Kahit sa thickness ng pag apply, di dapat makapal, basta't malagyan lang yung paint ok na, di na kailangang makapal talaga ang application.
- Aug 2009
- 1,553
July 24th, 2010 01:01 AM #9Yes QD's are for gloss and spray waxes offer little protection, but if you are refering to OGE, OGE is a QD and the only protection it can offer is the reduction of the bonding of solid particles on the paint, thats its main selling point and depending on preference also gloss, OGE gives a better mirror shine, NanoSliq on the other hand even though considered mainly as a QD also functions as a spray wax because it is designed to boost NanoGlos' gloss and prolong its durability and we have seen that i have been able to provide protection and durability not to mention great beading to the paint so in that sense we also consider it as a spray wax and a great one on that too, its look its more on depth as it sort of makes the paint a little darker so its great for dark colored cars to give out that deep wet shine.
you don't need to let it drip wet, take not we only mist it on the paint, just about 4 to 6 sprays tops on the hood and thats it, and like what migs said too much will just be a waste layering on too much won't give you any more benefit
as for the moisture on the paint thats the coating moisture thats being stated on the label, it means you've already put on too much if it becomes noticeable, so slow down on using NanoSliq, one 500ml bottle could last us a whole month and just imagine the number of cars we detail and maintain.
as for leaving the waxes to cure, my take on that would always be to follow to manufacturers directions, if its a WOWO product then do as it says and wipe it off as soon as you apply it, if its says let dry to a haze, then do the finger swipe test to see if its dry, if it says let is dry for 30 minutes to 1 hour then do so, but generally waxes are WOWO method ( thats wax on wipe off )
- Aug 2009
- 1,553
July 24th, 2010 12:53 AM #10Its ok if you use Sliq and then OGE but not OGE then Sliq so yes you are right on your assumption about OGE
but if you ask me you should choose between sliq and OGE, choose one only and nowadays its rainy season Nanosliq so far has been the best QD/spraywax out there and the cost definitely pumps up its value
Tesla Philippines
