Page 3 of 158 FirstFirst 12345671353103 ... LastLast
Results 21 to 30 of 1575
    Aug 2009
    #21
    Quote Originally Posted by dbhollanda View Post
    pwede kaya gamitin to pantanggal ng very small talsik ng spray paint sa body ng car? ok kaya kung wash, clay, then this product, then yung polishing ng megs din, then maybe nano, carnauba, then nanosliq? -- para pantanggal ng minute talsik ng white spray paint?
    Hmm i would recommend you using claying first, if its still there hit it with at most 3 more passes, if its still there then you might need to try a more aggressive clay bar, if its taken out then just use a polish to clean the dulled surface, if its still there i would recommend you try this product but with moderate pressure only, no heavy pressures with this product, if its still there, get some shampoo and 2500 grit wet sand paper and wet sand the part and return the gloss with this product.
    Jun 2007
    #22
    Regarding next detailing EB, ewan ko lang hehe. Pero sana meron this October, sembreak ko na next week!
    it was nice meeting you kanina bro! thanks very much for the tips, will surely look forward to that detailing EB...
    Apr 2008
    #23
    Quote Originally Posted by madkatz View Post
    with OCW you just use it like a QD but on a clean surface, you apply some on the MF first and about just one spray on the panel will do, this will already cover a lot of paint area
    as with the Zaino question, it depends z5 can be layered immediately after doing the whole car and removing it from the whole car, once you done, you're ready to layer again starting from the first panel you previously layered, but this is best if left for 4 hours based on experience with the zfx, with Z2 if needs about 4 hours minimum for extended durability and 8 hours recommended, the producer says it can be layered immedaitely after doing the whole car but i don't that it doesn't stack as much when done this way
    1. parang gusto ko itong zaino ah kasi mas maikli waiting time compared to carlack...pero ms madkatz which is better carlact or zaino..
    2. kung mag double wax ako and 915 would be may LSP....ano yung base product (don't know the term to use, so pls correct me) na pwede ko gamitin before applying 915
    3. kasi either this weekend or next weekend mag zero out ako...eto po steps ko..pls correct po
    wash and dry..
    apply kerosene to whole car (due na talaga especially the lower panel)
    remove kero by degreaser and rinse again with water
    dry again..
    apply carlack AIO
    apply long life sealant
    wait for 24 hours (kaya I'm looking for a less curing sealant)
    apply long life sealan (2nd coat)
    wait for 24 hours
    apply 915
    after two weeks wash,clay,915
    after weeks ulit wash, double wax (cleaner carnauba,IPA,915)
    Mar 2005
    #24
    thanks! Applied 2 coats of Z5 at 1hr intervals and after 2hrs 1 coat ng z2. Very deep gloss kesa klasse twins. Sayang di ko maantay yung 4hrs na curing time next detail session ko ulit. Then ocw lsp ko
    Mar 2005
    #25
    yung zaino kaya mabilis mag cure may ihahalo pa na zfx flash cure additive. Pag wala nun same din ng klasse yung curing time.
    #26
    Hello, i think he would be free this weekend since so far we still don't have any plans and none scheduled on our calendar
    I would recommend you show it to him personally so that he could asses the problem better, that way you could try and find out which one works and which one doesn't as usually we always go the safest route.
    thanks po mam madkatz, try ko po pumunta sa kanya if ever di matuloy yung plans po ng family sa sunday.
    *chicks, thanks sir
    Jun 2010
    #27
    *sir rico
    Grabe sir buti pa kayo. Ako 13 days pinakamatagal na tinagal sakin ng 476S eh. Double coat pa yun ha. Pero the 2nd coat was applied 2 days after yata.
    Sir bale every week after washing, OCW ginagamit nyo?
    I wash my car and use OCW twice a week... Wednesdays and Saturdays..
    pero pag umulan, I'd either hose down my car, or do a waterless wash, tpos sliq...
    I just had to get over the obsession for beading.... before kc it was my basis kung may wax pa o wala.... pero with OCW kasi, the beading is lost easy, but the look and feel of it, the ease of removing dust and the sheeting of the water shows that the wax is still very much intact...
    Oct 2008
    #28
    Quote Originally Posted by rico_g View Post
    ..I just had to get over the obsession for beading.... before kc it was my basis kung may wax pa o wala.... pero with OCW kasi, the beading is lost easy, but the look and feel of it, the ease of removing dust and the sheeting of the water shows that the wax is still very much intact...
    so OCW sheets. so far beading and sheeting are the primary bases for the presence and endurance of the product, but we know better to not base solely on those manifestations.
    [SIZE=1]Thesaurus.hmmmn ... [/SIZE]
    Oct 2008
    #29
    Quote Originally Posted by Hardinero View Post
    wash and dry..
    dry again..
    apply carlack AIO
    wait for 24 hours
    apply 915
    for a fast curing LLS try to ask around for Polycharger H2O.
    do you rinse before degreasing?
    please check your claybar and cleaner wax against LLS. it's a great opportunity to experiment whenever the paint is bare of detailing products.
    try on lower rear doors. doors are shiny even on a less detailed state when viewed at 30 degrees or less.
    no need for IPA after cleaner carnauba.
    Apr 2008
    #30
    Quote Originally Posted by indiej View Post
    paps, thanks for the headsup on the IPA..
    ang gagawin ko paps, if ever na halimbawa feeling ko mag-expire na yung AIO and sealant...most probably in 3months wala na yung 2 coats no?
    and if that happens tapos tinatamad akong mag sealant eh..double waxing na lang..
    1) prep the paint by wash and clay
    2) cleaner carnauba wax
    3) 915
    may nakapagsabi nga sakin re polycharger kaso mahirap ata mag-hanap..
Detailing Thread [For Newbies][continued 2]
