Results 1,061 to 1,070 of 1575
December 7th, 2010 08:15 PM #1061
- Dec 2010
- 129
December 7th, 2010 08:58 PM #1062sir carlack "twins" meaning 2 types? both are sealants and should go together? then after that dun palang mag aapply ng 476 then a wax booster like OCW/sliq?
may nababasa pa ako na cleaners para maganda daw ang kapit ng wax, anong product naman yun? is that another step again prior to the application of sealants then wax and so forth??... uuugghhh..
-Aris.
- Aug 2009
- 1,553
December 7th, 2010 08:59 PM #1063
- Aug 2009
- 1,553
December 7th, 2010 09:02 PM #1064klasse twins has 2 components KAIO and KSG, KAIO is a cleaner sealant already that can be used as a pre-wax cleaner, pre-wax cleaners is what you would be referring to as the product that allows maximum bond with the paint so if you get klasse twins you already don't need a pre-wax cleaner
- Aug 2009
- 1,553
December 7th, 2010 09:02 PM #1065
- Dec 2010
- 129
December 7th, 2010 09:11 PM #1066I see, ok so basically its
1. claying
2. KAIO
3. 476s
4. OCW (and also for maintenance in between washes)
tama po ba?
...maam, sorry but san dun kasama yung KSG?... also, is "carlack" and "klasse" the same? I'm assume it is coz you referred to it as such... just making sure tho.. Thanks again!
-Aris.
December 7th, 2010 09:16 PM #1067
let's just call the time a product has hazed and dried and ready to be buffed-off as drying time. LLS - 1 hour drying time, 24 hours curing time.
dandy, with waxes, use the finger swipe test to see if it's dry and ready to be buffed-off.
just in case.. finger swipe test (0.19 seconds in Google). faster than a reply post.
smear don't slather. if you wipe it on and the paint looks wet, however little you think you've used, you're doing it right. if you can make it even less, good for you.
December 7th, 2010 09:40 PM #1068
December 7th, 2010 09:47 PM #1069
my bad...
i was actually referring to drying time na 1 hr sa carlack sealant. pero ang aio ng carlack e alang drying time -- meaning pagka apply mo e balik ka na don sa unang panel na inaaplyan mo then buff off.
tama si mam madkatz -- dapat super nipis lang ng application for both products. never pa naman ako nahirapan i-buff off yung sealant considering by hand lang ang buff off ko.
oo nga pala...and it's just me...ang application ko ng aio at sealang e pahaba not pabilog...i.e. kung sa side panel e from top to bottom ang apply ko pababa..not typical na pabilog parang for me e mas madali ang application...but then it's just me...and i'm not saying na mali ang paikot na application...
- Jul 2010
- 44
December 8th, 2010 01:51 AM #1070mga boss help naman, i think i damaged my paint due to continuous rubbing ng clay. kasi may parang mga small dots or talsik ng paint na nakadikit sa paint ko kaya ang ginawa ko, ni-rub ko yung clay dun sa mga parts na yun hanggang sa matanggal yung mantsa na yun. mas maganda pa siguro kung ginamitan ko nalang ng kuko para matanggal. so there, i guess i marred the paint by rubbing the clay too much and with pressure. para siyang scratches na kita pag naarawan at an angle. or parang oxidation ang itsura. ano po kaya pwede ko gamitin para dun? pwede na kaya cleaner wax? swirlx? or a more aggressive product? first time ko kasi magclay eh kaya d ko alam na pwede palang makadamage ng ganon.
Tesla Philippines
