Page 486 of 591 FirstFirst ... 386436476482483484485486487488489490496536586 ... LastLast
Results 4,851 to 4,860 of 5910
    Mar 2005
    #4851
    Quote Originally Posted by azzkkr2600 View Post
    pre may stock ng collinite 915 si sir edwin / sir jerome. tig P1200 yata isang lata.. hindi kaya overkill 476s+915? mag optimum ge qd ka muna.
    bili na rin tayo optimum no rinse bro. sinong makikihati?
    Hindi overkill yan ginawa ko sa tucson 915 muna tapos after a week and 1 wash 476s naman. Kitang kita pa din yung shine ng 915.
    Bang for the buck talaga yang 915 sa price na 1.2k sa Jazz ko 1 week ng nag uulan tapos nagpa carwash lang ako kagabi ang kintab pa din niya parang kakalagay lang ng 915.
    Yung sa ONR nung ginamitan ko ng tap water from blue naging clear na lang siya pero mukang effective pa naman. Yung ONR ko na ginamitan ng distilled water blue pa din siya bakit kaya ganun?
    *Madkatz
    Na try niyo na ba gumamit ng Diamondite Glass Resurfacing Creme at Glass polishing pads? Sinubukan ko gamitin medyo mahirap kasii nag wowobble yung portercable sa windshiled ng jazz, pinanood ko sa videos ng autogeek kung pano yun gamitin tama naman yung paraan ko.
    Aug 2008
    #4852
    i have problems with watemarks all over the body.
    similiar to this pero hindi ganyan ka grabe.(pahiram po ng pic mam madkatz)
    tried using claybar+cleaner wax+swirlx nabawas pero andami padin. pero combination na yan natanggal ko. watermarks sa vios.
    what products should I use? I've read from meguiar's forums that scratchx2.0 would remove these. di ba same scratchx and swirl x?
    wala kasing detailing shop dito sa province namen AFAIK.
    thanks!!
    Mar 2004
    #4853
    Quote Originally Posted by ratchet23 View Post
    thanks!!
    If the Claybar + cleaner wax + swirlx combo was not able to get rid of the watermark, it can be due to one or both of the following:
    • The watermark is etched on your paint. Check the watermark closely... try to feel it with your fingertips. If it ain't raised above the paint, it's already etched into the paint. This is usually caused by acid rain that was allowed to dry under the sun. If the watermark is etched, then yes, you'll need something more aggressive than SwirlX. ScratchX may do the job, if you're working by hand.
    • Sobrang nag-tutong na yung watermark. Calcified water. Nasty. But not as bad as etched watermarks. Try a water+white vinegar solution (sorry... I don't remember the dilution ratio...). If it works, make sure to wash and re-wax the treated surface.
    Jun 2007
    #4854
    natest yung 476 nung sinundo ako from manila... inulan ba naman. hehe
    galit nga talaga sa tubig ang collinite... eto yung beading after ma shampoo!
    one layer nga lang pala yan ng 476 mga sir
    medyo dull nga ang 476 on its own...
    kaya eto. after ng mother's FX spray wax, then nanosliq.
    kintab ulit! bukas dapat makuhanan ko na to in sunlight
    two thumbs up talaga to collinite waxes. thanks for suggesting it, fellow tsikoteers!
    Mar 2005
    #4855
    thanks!!
    By machine mo ba ginamit ang swirl x? Ang scratch X 2.0 ay mas aggressive kesa sa swirl X. Depende din yan sa pad na gagamitin. Kung by hand mas maganda siguro na Ultimate Compound na ang gamitin diyan
    Abrasive charts
    http://craigdt.web.officelive.com/abrasives.aspx
    Aug 2008
    #4856
    ok by hand lang po. ok will try ultimate compound. tnx! pwede i apply yun buong car?
    Mar 2005
    #4857
    Mas maganda machine sir tanggal kagad yan kahit swirl X lang. DI na siguro kaya matanggal by hand yung watermarks nyo.
    #4858
    Hindi nakaka tanggal ng watermarks ang by hand. Mahihirapan ka sir. Pagawa mo nalang po sa professional..
    Sabi ng BigBerts sa akin kailangan daw machine ang gamit sa Klasse AIO
    Feb 2010
    #4859
    eto sureball....mala kobe ang dating.....gamitan mo ng DIAMOND CUT yan using the yelow pad...(syempre makina na gagamitin)....tapusin mo ng FLEET ayus ang butobuto.....
    just got home....kapagod...tom na maglinis...mga 5am....hehehehehe!!......lagyan ko 2nd layer 476....pag tinamaad hugas sabay OGE
    Feb 2010
    #4860
    Quote Originally Posted by aejhayl17 View Post
    painum ka na sir PSI! haha kila doc tayo!
    sorry OT:
    naku di mo ko TXT eh....ngayon lang me nagbasa....science
