Results 91 to 100 of 105
- Jan 2008
- 66
March 15th, 2008 06:51 AM #91I realize that the previous link to this software is now dead. You guys can try this one. I downloaded it and it works fine, after unzipping and installing you just need to replace the dll file included and it should have a November 2005 date after replacing it. It's the same software that the Lotus Car Co in the UK is using to develop their cars. Kindly share nyo na lang sa iba including our manufacturers and academe if possible kc its one way that might encourage them to actually design cars/parts if they have these tools at their disposal. Here's the link;
http://**********.com/files/706581/Lotus_RUZ.rar.html
Here's the company's website;
http://www.lesoft.co.uk/
Nice article about Lotus helping to develop the Proton Saga G2;
http://www.edmunds.com/insideline/do/News/articleId=124465
- Jan 2008
- 66
March 15th, 2008 12:45 PM #92The emule links are not really dead per se. It's just that you have to wait patiently for someone to seed the file that you need to download. I've experienced downloading a software for 2 weeks before it completed. Then again, I guess that's the price to pay for obtaining something for free or close to free (DSL fees come to mind). Believe it or not, I've downloaded tons of CAD / Engineering software via emule that would've cost hundreds of thousands of dollars already had I paid for them. If only our manufacturers or even the small backyard latero industries were only aware of these "backdoor" sources they would be using some of the cutting edge software tools used by the Japs, Europeans etc. in the field of automotive design and manufacturing.
Examples are CNC simulation, Casting Simulation, Stamping Simulation, Engine Simulation, Crash Simulation, Vehicle Simulation etc.
In case you're too impatient here's another ******* download link for ANSYS
you can also use this software for Aerodynamic Testing of Car Bodies. You need to have Bit******* or u******* installed first to download this.
http://www.btmon.com/Applications/Unsorted/ANSYS.ICEM.CFD.V10.0-MAGNiTUDE.*******.html
Here's another emule link for Flow3D
http://ed2k.earthreactor.com/Wce470e564b76c.htm
March 16th, 2008 12:47 AM #93
I want this sir, but it's dead.
Lotus Engineering Software - All in One
http://**********.com/files/11137554/Lotus_Software.rariam3739.com
- Jan 2008
- 66
March 16th, 2008 05:12 AM #94Drey,
The new working download link to Lotus Engineering Software is at my Post #91 above. The first link directs you to this software. It's the same software when you unzip it. It has Engine Sim, Vehicle Sim, Suspension Analysis, Concept Valve Train and Concept Crank Train etc. It even has help files and manuals in Pdf format so you can just self study the program.
- Jan 2008
- 66
March 20th, 2008 12:55 PM #95The following emule link will direct you to Camtrax and Geartrax 2007 software that are good tools for designing engine cams and manual/automatic transmissions.
CamTrax and GearTrax 2007
ed2k://|file|Camtax%20-%20Geartrax%202007%20Crack.rar|19021518|5E035BC03C F760E74FC9070E72286B97|h=UGYWTA4DMKMTGCYQZBVQMY7NH M6V2INT|/
March 21st, 2008 10:52 PM #96
- Jan 2008
- 66
March 27th, 2008 06:34 PM #97ENGINEERING SOFTWARE COLLECTION VOLUME 6 FLUENT FOR THE AUTOMOTIVES
FLUENT V 6.2 Flow Modeling Solutions for the Automotive Industry | LATEST RELEASE
WINDOWS OS | ENGLISH |SIZE 600 MB APP | SOFT + DOC FULL| CAE SOFTWARE
Fluent's CFD software products enable you to create virtual flow models within your computer quickly and effectively to quantify, visualize and optimize automotive designs early in the design process. The insight and efficiency that you will gain from using FLUENT will result in better designs in shorter cycles. FLUENT meets all of your automotive CFD needs, from component-level to full vehicle analyses. The unprecedented array of robust and accurate models permits for the simulation of the widest possible range of automotive CFD applications in the industry, including aerodynamics and thermal management, climate control, engine modeling, exhaust aftertreatment, acoustics, multiphase and multiphysics applications.
Our software couples to industry-leading PLM, CAD and CAE software to ensure integration into your design process to provide the best simulation solutions quickly. We offer a full range of products and services including highly automated flow modeling tools that allow design and process engineers to perform flow and heat transfer calculations. We continually help automotive companies realize the benefits of CFD, aiding in both its initial deployment as well as the continued application to the overall design process.
Let us show you how FLUENT can reduce your product development and manufacturing costs and enhance your return on investment.
Here's the link to the Free download. Enjoy!!!
http://www.ftp2share.com/file/10707/fluent for the automotives.html
March 31st, 2008 06:32 PM #98
- Jan 2008
- 66
April 7th, 2008 10:40 AM #99Theory and Design of Auto Engines Lecture Notes - VTU e-Learning
Introduction
http://**********.com/files/105212734/Theory_and_Design_of_Automotive_Engines_-_Chapter_1_-_Introduction.pdf
Two Stroke and Four Stroke Cycle SI Engines
http://**********.com/files/10521305..._SI_Engines.pd
Cylinder Heads, Cylinders and Liners
http://**********.com/files/10521337...and_Liners.pdf
Pistons, Piston Rings and Piston Pins
http://**********.com/files/10521356...iston_Pins.pdf
Connecting Rods
http://**********.com/files/10521365...cting_Rods.pdf
Crankshaft
http://**********.com/files/10521373...rankshafts.pdf
Flywheel and Camshaft
http://**********.com/files/10521405...d_CamShaft.pdf
Valves and Valve Mechanisms
http://**********.com/files/10521478..._Mechanism.pdf
April 30th, 2008 10:35 PM #100
Invited ang may locally fabricated na vehicles sa DES-DLSU-D-Tsikot (?) Car/Auto Show in DLSU-Dasmarinas this coming September 1st semester SY 2008-2009.
For particulars PM JPDM.
