Page 5 of 20 FirstFirst 12345678915 ... LastLast
Results 41 to 50 of 197
    May 2004
    #41
    Unang beses ko iddrain to sir. 5 yrs na kasi and recommended sa manual kada 5 yrs papalitan. Mula bnew di sya nabawasan sa reservoir.
    What do you mean by rinse? With distilled water pa rin ba although di na pupunuin yung rad? Sorry got a bit confused there. Btw still planning to use OEM Toyota Long Life Coolant.
    I think pwede na drain and fill na lang...
    Jul 2006
    #42
    Quote Originally Posted by EVO-V View Post
    Your distilled water does nothing, it is a placebo at best in most applications, unless you're comparing it with ground water.
    So what is the point of this thread then? Distilled water, is water in its purest (and cleanest) form.
    RE: Why Water Quality Matters
    Oct 2011
    #43
    aside from cooling down your engine remember that coolant has an anti-rust property to protect your radiator.
    Dec 2009
    #44
    i still prefer the distilled water... pag galing sa maynilad mataas chlorine content, tapos madame din sediments...
    i think mineral water sa water stations pwede na provided na mag coolant ka..
    Jan 2008
    #45
    nadale mo sir...
    so pag nag coolant ka you can use any kind of water?? tama ba??
    q: sa mga pre mixed coolant na binebenta.. may halo ba yan na tubig?? o wala??
    Aug 2005
    #46
    Quote Originally Posted by 1997 View Post
    It helps to flush. By rinse I mean rinse with clean tap water. The OEM long life coolants are pretty reliable. Not the best but better than most aftermarket products.
    May 2004
    #47
    Quote Originally Posted by miko101130 View Post
    don't use mineral water.. kasi may minerals yan.. dapat distilled... never use tap water... kasi may maiwan na residue dyan... buy distilled kahit yung sa SM bonus....
    Dec 2009
    #48
    Sir the minerals doon sa mineral water sa mga refilling stations ay super baba na talaga as in ppm count na,.... The amount cannot be compared sa tap water ng maynilad na pati sediments visually nakikita ng mata...
    Aug 2005
    #49
    Point is by demonstration of an extreme situation is what NOT to do. Distilled is the other end of the extreme and is pretty much a placebo.
    Aug 2005
    #50
    Use bottled water if and when the water in your locality is very hard. Distilled water really does nothing but provide peace of mind. Then again it is your money, go knock yourselves out.
