Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 61
    welcome to the waterpump replaced club [emoji28]
    Feb 2014
    #32
    i bought this OBD2 gadget. able to set overtemp alarm. etc
    Mar 2007
    #33
    Old water pump.
    New water pump.
    More often than not, water pump talaga ang salarin sa overheating. Ended up replacing the radiator (well due narin naman talaga for replacement) thermostat and radiator cap. Water pump pala ang sira. Pero ok lang at least my cooling system is top notch again.
    GMB water pump 2,800 bili ko. Not bad. Magandang brand na raw ito.
    nice 🖒
    Mar 2007
    #35
    Partly negligence ko rin. When the radiator was convered to brass tank, hindi ko na siya na refill ng coolant. Distilled water nalang. It took 2 years for the impeller to disintegrate.
    Kaya lesson learned, pure distilled water can cause accelerated degradation of your water pump.
    Quote Originally Posted by suysuy View Post
    distilled water doesnt have corrosion inhibitors. two kinds of metals will cause bad corrosion..
    Apr 2014
    #37
    Diba distilled water is as good as coolant?
    Di nga lang ganon ka effective sa cooling pero hindi sya mag foform ng rust.
    Quote Originally Posted by chronicle View Post
    lower boiling point - coolant
    rust protection- coolant
    distilled is only for temporary use.
    Jan 2008
    #39
    Old water pump.
    New water pump.
    Ubos yung impeller.. usually pinapalitan ang water pump sa timing belt change.. gmb is a good brand.. pinalitan mo na din sana ng oem gasket..
    After a month or on next maintenance, drain mo ulit coolant mo to make sure na malinis ang cooling system.. medyo rusty na based in your old water pump
    #40
    Water dissipates heat better. Coolant(glycol based) is mixed to raise the solution's boiling point, raise water's PH, push corrosion back....& those in temperate regions, this will serve as anti-freeze.
    Periodic coolant swaps are required as it will degrade & turn acidic over time. Check the PH level of coolant annually. It should be maintained between 9.5-10. If it goes below 8, swap ASAP. Your engine, water pump, radiator, heater core will thank you for it.
    For those who are going for a complete engine overhaul, take this opportunity to go Evans Waterless Coolant & stop worrying about periodic coolant swaps. Evans CANNOT be mixed w/ water. System should ideally be free of water upon switching.
    Evans coolant stops engine problems due to water
    http://www.evanscooling.ph/products/...rmance-coolant
What's your coolant temperature?
