Results 31 to 40 of 44
- Jan 2008
- 4,726
May 20th, 2015 08:21 PM #31Evaporator temp is around -5deg celsius or lower. It will freeze if condensate is trapped usually by dirt or not enough air can pass due to clogged cabin filter. air at vent should be at 10deg celsius or lower to have that 20 to 25 deg celsius real feel
- Jun 2008
- 360
May 25th, 2015 03:11 AM #32Saan makakabili ng Magamdang Aux Fan? Feeling ko kasi ito problema ng Sasakyan ko(isuzu alterra).. Malamig ang AC kahit naka-idle pero kapag tumagal nga lang ng mga 30min na babad sa araw parang nahuhuli yung pag-andar ng compressor para lumamig.. Kasi kapag hinihila ko wiring nya bumibilis ang ikot ng fan.. Kapag binitawqn ko bumabagal.. May napagtanungan kasi ako yung motor lang ng Aux Fan( orig pang-nissan navarra (japan)-same naman daw ng para sa Alterra ang presyo 8.5k ).. NgaNga tuloy ako.. Inaasahan ko buong Aux Fan mga more or less 3.5k lang..
May 25th, 2015 10:12 AM #33
May 25th, 2015 10:27 AM #34
May 25th, 2015 03:50 PM #35
- Jun 2008
- 360
June 5th, 2015 03:46 PM #36Problem Solved na.. No problem sa Wiring.. Yung motor mismo ng Aux Fan ang Sira kaya pinapalitan ko na.. Ayun, back to normal na ulit even at real feel 41 degrees celcius na nakababad, tirik ang araw na naka-idle..��
Problem Solved na.. No problem sa Wiring.. Yung motor mismo ng Aux Fan ang Sira kaya pinapalitan ko na.. Ayun, back to normal na ulit even at real feel 41 degrees celcius na nakababad, tirik ang araw na naka-idle..👍
- Nov 2019
- 2
November 20th, 2019 02:26 AM #37Same issue. Mitsubishi Strada L200 4x4 MT (1999).
Need ko ba palitan yung evaporator, condenser at upgrade yung blower? May nagsabi rin na pag OEM, hahayaan na lang but it seems older models’ air conditioners doesn’t work the same as modern models (for example, Innova 2016 and Hilux 2017 in my experience, kahit idle o nainitan, lumalamig parin).
November 20th, 2019 04:28 AM #38
- Oct 2006
- 6,091
- 53,883
November 20th, 2019 09:02 AM #40
Tesla Philippines
