Results 11 to 20 of 21
- Nov 2006
- 201
July 29th, 2010 05:09 PM #11
- Nov 2007
- 164
August 1st, 2010 04:27 PM #12
August 4th, 2010 04:33 PM #13
anong model? i'm not sure kung pareho. ung sa civic 98 namin AFAIK is mechanical ang nagpapainit ng aircon. may nabasa ako regarding dito sa ibang forum. so sabi kahit naka sagad sa pinakamalamig yung aircon mo pareho din consumption niya. kasi laging naka engage ang compressor. subukan ko hanapin yung post pag sinipag. better ask kung ganyan din yung sa city. mas ok pa kung manually mo i off once in a while ang a/c and gawing fan.
August 4th, 2010 05:44 PM #14
Kung di naman masyadong mainit, yung katamtaman lang sa thermostat setting ay ok na...
Kung talagang sobrang init, next to the lowest temp setting ng thermostat, doon ang the best...
Kapag naka-Max ka, walang pahinga din ang Compressor.
Tungkol naman sa fan, hangin lang yan, walang pinagkaiba (kung malakas o hindi) sa tanong mo....
pareho lang....
- Mar 2009
- 184
August 4th, 2010 06:10 PM #15If you want it to be economical, the best setting is what's closest to the outside temperature
kasi the compressor will almost always be off.
Siyempre, ayaw mo yan. Maiinit yan.
The next best thing if you ask me is if you have a car with climate control, just set it to the best room temperature between 22-24 degrees. Colder than that, you'll make the aircon work harder = more FC. Hotter than that, and you'll be sweating.
If its a manual A/C go 50-60% depending on the temperature that you feel. Mahirap yan, kasi tantsa-tantsa lang...
Anyway, the reason why I also mentioned 22-24 deg is because I think its also best for your health. You don't get "thermal shock." Pag masyadong malamig sa loob, at masyadong maiinit sa labas, our bodies is less able to handle the sudden swing in temperature, and you'll likely get a sore throat or colds.
August 4th, 2010 06:19 PM #16
Forget the blower/fan for a minute.
OTEP's answer sheds some light as to exactly HOW an aircon compressor works.
Moving the thermostat actually just influences how often and how long your compressor's clutch is engaged. A high cooling setting means the A/C compressor clutch is engaged for longer periods of time before it stops, although it will have longer breaks. The reverse is true for a low cooling setting (more frequent breaks but shorter engagement periods). If you're observant enough, you can actually HEAR the clutch engaging and disengaging.
Since the clutch is engaged longer on a high cooling setting, you burn more fuel...but regardless of what position your thermostat is in (or even if your A/C is on or off), your compressor will still be spinning every time you run the engine because it's connected via a belt.
So now you know WHY the second option is easier on fuel.
- Apr 2009
- 137
August 4th, 2010 06:24 PM #17from what i understand, tumataas ang fc mo pag nag aircon ka kasi the engine will exert more effort to run the a/c compressor thats why tataas ng konti ang idling mo.. pacorrect po kung mali.
how about kung after mo i-on ang a/c di naman tumataas ang idling mo.. may difference pa din ba sa fc?
August 5th, 2010 02:33 PM #18
eto nga pala yung nabasa ko regarding don sa post ko.
http://s3.zetaboards.com/HCP/single/...3415&t=7180395
i'm not sure kung tunay.
- Jun 2006
- 1,139
August 5th, 2010 08:50 PM #19cut and paste mo na lang bro, para di na kami mag register. kelangan registered ser para ma access ang link.
August 5th, 2010 09:11 PM #20
This is where the clutch comes in. When it's engaged, the A/C compressor contributes to A/C cooling, but at the same time adds load to the engine. Disengaged, it just free-wheels - less load on the engine. As mentioned, the frequency and duration of engagement is controlled via the A/C thermostat.
On an SX8 Honda City like the threadstarter has, there's a separate button for turning the A/C compressor on and off. When it's off, the clutch is disengaged and it free-wheels - only the blower is operational.
Now, the blower itself is usually an electrical component, not mechanically driven from the engine like the A/C compressor is. There's still some parasitic load on the engine when the blower is on, but far less than what the A/C compressor would have. Less load on engine = less fuel burned.
Tesla Philippines
