Results 11 to 13 of 13
- Mar 2014
- 901
April 19th, 2015 08:34 AM #11* StarLord, your ride is a Honda Accord 2000 pala. Whether it is an A/T or M/T, better put back the thermo-switch and thermostat valve when your able. For sure, you have some reason why un-install those two component parts in your cooling system.
Sent from my Starmobile UP+ using Tapatalk
- Mar 2014
- 901
April 19th, 2015 09:10 AM #12*StarLord, if you can't install back both parts, kahit yung thermo-switch lang muna maibalik mo. Thermo-switch is a sensor to your cooling system which automatically turn off/on the fan motor of your radiator in a certain temperature. Running at high speed in an expressway or highways, with thermo-switch, your fan motors will not turn on due to malamig pa coolant mo dahil napapalamig ng hangin sa pagtakbo mo. Without thermo-switch, napapalamig na ng hangin sa bilis ng takbo mo, andar ng andar pa rin fan motor para sa radiator. Dyan ka madalas magpapalit ng fan motor at relays.
- Jul 2003
- 573
April 20th, 2015 09:48 PM #13there are two thermoswitch installed. make sure both are good. they are rated differently, so do not interchange them. anyway, you will know if you have the wrong thermoswitch, the connector will not fit properly.
