Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 51 to 60 of 85
    May 2013
    #51
    jeDi13,
    never pa...yata. i got my car 2nd hand. hindi ako bumibili ng bago, bro...walang pambili hehe i guess the previous owner didn't bother as long as the car is running. first time ko kasi ma experience yun tumaas ang temp at highway speed. yun sa isang sasakyan kasi, sumabog yun top kaya hindi ko na inantay mag overheat.
    btw, pwede ba linis lang? o talagang overhaul kaagad? puro kalawang at sarado na yun mga butas nung binuksan.
    Aug 2004
    #52
    Mahirap ata maglinis without removing the top kaya nagiging cleaning = overhaul. Kung coolant ang ginamit I think you can get away with a radiator flush every 80k kms (have to check the manual for that). Kung tubig lang mas madalas ang overhaul because of the rust.
    May 2013
    #53
    i see. naglagay ako ng coolant nung nagpalit ako ng timing belt. naubos na daw hehehe ilang coolant ba dapat? balak ko i-drain yun tubig pero test ko muna 1 week kung talagang hindi na nagbabawas. pag ok na, drain ko na yun tubig tas papalitan ko na coolant. san pala nakakabili distilled water?
    Aug 2004
    #54
    Absolut distilled pwede na. Kung ok na sya mas kampante ako sa pre-mixed coolant like Prestone. Kelangan kasi tama ang ratio ng coolant concentrate to water. Dala ka na lang ng extra sa trunk.
    Jun 2007
    #55
    ah kaya pala. hindi naka-coolant yung previous owner. kung may nakikita kang rust pa rin, i suggest magpa-overhaul ka ulit after 6 months.
    usually 3-4 liters ang kailangan. i agree with johnM, konti lang difference ng premix sa concentrate. mas sigurado ka pa sa mixture ratio.
    May 2013
    #56
    sige nga titingin ako ng pre-mixed coolant. anong brand gamit nyo? buong buhay ko, tubig lang gamit ko. ngayon lang ako nag inarte hahaha wala kasing internet noong araw bwahahaha
    Jun 2007
    #57
    nag-try ako ng Prestone dati, both on my father's sentra and my EK Civic. pero shortly after, biglang nag-overheat hehe.. inisip ko noon baka hindi maganda Prestone. or maybe madumi na rin cooling system and baka barado na radiator. and nung nilagyan ko ng coolant, baka lalong bumara, or just coincidence.
    anyway, wag ka na mag-tubig. actually, oks lang naman, pero hindi tap water ha. at least man lang distilled kung ayaw mong magaya yung kotse mo sa sentra ng father ko. twice top overhauled. pinalitan ng hoses, rad cap, thermostat, thermoswitch, and yung labor. siguro inabot din siya ng 15K dahil lang nagtipid at tap water lang nilalagay hehe
    nabenta ko na EK civic ko. yung sa ES ko ngayon, Honda coolant na gamit ko.
    Apr 2010
    #58
    Pro99 coolant currently yung sa akin mura eh hehe. 150 for a liter concentrate, bought 3 so good for 6 liters sya sakto sa na-drain ko. Sa next drain/flush ko baka mag 4 or 5 bottles ako since may natitirang water pa sa loob that I cannot drain, di ko makita engine drain plug. For topups water galing sa refilling stations ang nilalagay ko
    Nagpa overhaul ako kay Jorge one time (of Jemson Electrical / Jorge Radiator shop ng Banawe, see Electricals forum). Halos orange na yung kulay because of rust Sinabay ko na lang palit ng upper and lower radiator hoses. Kung dati umaakyat ako ng Tagaytay umaabot sa 1/2 yung temp guage pagkatapos ko magpagawa mga 1/6 - 1/8 na lang hehe
    May 2013
    #59
    hindi ko napapalitan yun hoses...yun ibabaw lang ginawang tanso. sabi kasi nung gumawa, ok pa naman yun hose. eto pa, wala daw thermostat na nakalagay, pwede na daw maski wag lagyan? sa weekend check ko nga ulit yun tubig kung nabawasan.
    next month byahe ulit ako, sana hindi na tumaas temp at highway speed.
    May 2009
    #60
    Quote Originally Posted by gutz_3110 View Post
    brader, kung kasinglambot ng ispongha yung lower hose ng sasakyan mo e tataas yung temp sa highway speeds. dahil sa sobrang bilis ng sirkulasyon ng tubig e nagcacavitate or nagkakaron ng vacuum therefore mas kokonti tubig na iikot (o "hangin" ang iikot). that is, assuming lahat ng piyesa ng cooling system mo e maayos bukod sa lower hose.
    kumbaga parang sumisipsip ka ng inumin gamit ang straw. kapag mejo bilisan mo ang pagsinghot este pagsipsip, nagcocollapse ang straw at wala ka na masipsip na inumin.
Overheating at High Speed (revs) and uphill
