Page 6 of 6 FirstFirst ... 23456
Results 51 to 60 of 60
    Feb 2009
    #51
    Did anybody in any of the shops you mentioned perform pressure test on the rad cap and the cooling system? There had been too many v Hunches and your car is still overheating. Do a proper diagnosis first
    Sep 2016
    #52
    Quote Originally Posted by LN106G View Post
    Is your new radiator the OEM or a replacement brand? It could also be that your water pump is leaking but not overt and leak dries up immediately with the warm engine. You mentioned the first time that your car overheated and it died along the way. this is not a good sign and could probably mean a warped or cracked cylinder head. check your dipstick if your engine oil is "milky" in character. Oh, in most toyota vehicles that i've seen and owned, i never saw a radiator cap with a 1.1 rating...
    Sir replacement brand yung radiator, bagong palit ang water pump at thermostat. walang makita na leak anywhere sa mga hoses, etc. walang signs ng kahit ano sa dipstick, takip ng engine oil, walang any sign of water or oil sa spark plug sockets. rad cap bago rin. Pinalit ko sa orig rad cap ng vios then long drive, same issue pa rin.. baka dun na ako sa top overhaul pagnagkaron ng budget. salamat mga sirs..
    Apr 2012
    #53
    Oct 2009
    #54
    aba high pressure na nga siguro yan.tanggalin mo nga ung rad cap mo saka mo paanadarin kapag may bula bula na lumabas sa radiator mo malamang mag pa top overhaul kana..kung rad cap problem mo
    Aug 2016
    #55
    Replace it.
    Engines don't like running cold.
    meron pa ba nabibiling thermostat dito sa Pinas?
    baka kasi mapagsabihan nanaman ako sa parts store na "napakainit dito sa Pinas, di mo kailangan nun!" eh from what i know parang bypass naman ang thermostat pag mainit na ang makina, and it just helps the engine warm up faster so the efi system would go closed loop faster, therefore mas matipid sa gas...
    Jun 2005
    #56
    Quote Originally Posted by carguy101 View Post
    Oo naman. Sa banawe madami. Sa pasay din
    Aug 2016
    #57
    Quote Originally Posted by sirkosero View Post
    ahh sige thanks.
    kasi nun one time sinabihan ako ng tao sa parts store nun bumibili ako ng langis na hindi ko kailangan ng multigrade oil dahil "napakainit dito sa Pinas"
    Jun 2005
    #58
    Sabihan mo lang na, gusto mo lang naman sya payamanin sa mas mahal ng multigrade kaya shut up na lang. Haha
    Aug 2016
    #59
    tama tama! hahahah
    thanks for the tip [emoji108][emoji817]
    Feb 2009
    #60
    Kids please do you homework.
Overheating?
