Results 11 to 20 of 25
May 17th, 2014 07:56 PM #12
May 17th, 2014 09:03 PM #13
May 18th, 2014 02:00 PM #14
Kung sobrang dumi, pwedeng yun lang ang cause ng blinking temp light mo,
Ilan na mileage ng vios mo? Original pa ba yung thermostat na nakakabit dyan
Since brand new yung auto?
May 18th, 2014 03:57 PM #15
- Oct 2009
- 2,271
May 18th, 2014 04:23 PM #16try mo kaya mag reset..
nag init paba nung pina labramon mo.at magkano labor.
ang daming issue ngayon sa overheating ng mga sasakyan,sobrang init kasi ng panahon.
kaya ginawa ko temporary hinugot ko muna ung socket ng thermo switch at nilagyan ng jumper
para naka rekta muna ung radiator fan ko.
siguro naman next month eh mag uu ulan na saka ko nalang ibabalik ulit..
- Jan 2013
- 82
May 18th, 2014 04:27 PM #17Removing the thermostat on an ECU controlled engine is a big No-No. At he very least this will result in lower gas mileage among other problems. Mekaniko siguro ng PUJ ang nag suggest syo nyan. Re install the thermostat as soon as possible
Sent from my Lenovo A60 using Tapatalk 2
May 18th, 2014 04:52 PM #18
ito din balak ko gawin kaya lang ang thermoswitch and water sensor ng vios ay iisa so pag hinugot ko hindi ko na mamomonitor ung coolant temp via obd2.
Ibabalik ko po ung thermostat bukas na bukas. I've read din kasi na lalakas sa gas and mas less efficient ang engine sa ganitong setup.
May 19th, 2014 01:51 PM #19
UPDATE : Naibalik ko na thermostat pero hindi ko pa nababago ung thermoswitch. bukas na. bali ang changes na napansin ko after lavramon ang bilis bumaba ng temp niya. temp ko hindi umangat ng 91 at nag 86 pa on a downhill. will try ulit tonight kung ok na.
May 20th, 2014 11:44 AM #20
UPDATE : Tumataas talaga temp kapag gabi w/c is dapat kabaliktaran dahil hindi naman mainit kapag gabi. Binalik ko na OEM thermoswitch. same sila magbukas ng replacement ng radiator fan * 96C. Will try kung bubukas pa ung overheat signal * 96C while running.
Tesla Philippines
