Results 21 to 30 of 40
April 22nd, 2011 09:14 AM #21
guys ok po ba yung given solution na patay A/c tapos let it run on fan bago patayin yung engine?
- Oct 2010
- 212
April 25th, 2011 11:57 AM #22for me it works.. turn the A/C off 3-5 minutes before you arrive at your destination para naman hindi naka-idle ang makina.. sayang din sa gas yun.. based from experience yan.. namaho din kasi A/C namin noon eh.. hehe..
basta 3-5 minutes far to your destination.. patayin na A/C..
- Oct 2010
- 212
April 25th, 2011 12:12 PM #23i've tried V7 car perfumes that you spray on the mats of the car.. then.. after kong i-spray yun.. namamaho siya kinabukasan.. that can be true.. or..
baka naman pinapatay mo lang ang A/C pagkapatay din ng makina? dapat 3-5 minutes before arriving to your destination.. patayin mo na A/C.. based on experience.. kasi yan din ang naging problema ko at yun din ang naging solution ko.. and it works..
April 25th, 2011 12:21 PM #24
May 17th, 2011 01:17 PM #25
- Oct 2006
- 7
June 1st, 2011 07:10 PM #26I will try the 3-5 mins before arriving to destination, 'OFF A/C - blower ON' solution. 'Hope this works. Baho din ng A/C ng Honda, amoy damit na hindi natuyo sa sampayan. Nakakahiya, pag may bago kang passenger, mapagkamalan pang ako yung mabaho.
June 2nd, 2011 03:57 AM #27
Try mong isabay pagpapalinis ng blower mo once nagpalinis ka ng a/c system. Usually ibinababad nila yan sa downy. Amoy downy na rin sya pagkakabit, hehehe. SOP sya sa Ceejay's sa may Alabang-Zapote Rd once nagpalinis ka ng a/c system sa kanila.
- Jun 2005
- 3,774
June 25th, 2011 05:57 PM #28afaik lysol is lye based and evaporators are aluminum.
lye corrodes aluminum which may cause premature evaporator damage...
June 25th, 2011 07:41 PM #29
Best remedy (not exactly the cheapest and most convenient) is to have your aircon system flushed and cleaned. For sure, tangal yang unwanted odor.
June 25th, 2011 10:30 PM #30
Consider also the the way you park your car on your garage esp on inclines. Evap moisture drain hose must be at the lowest level as much as possible. may not be the supreme solution though.
Tesla Philippines
