Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 62
    Feb 2012
    Aux fan nga sir siguro kulang, pag derederetso Kong binubuhusan ng tubig mga 5mins mag automatic na comp
    Jun 2011
    *sotel.. Gusto mas Lumamig pa..? May conversion akong ginawa sa mb140 ko.. Malaki improvement Sa lamig... Totally Walang high pressure... Kahit tanghali at naka standby Lang... Take note dalawa condenser Ko at 3 evaporator Ko pang gamit... Ta tahimik pati engine mo... Pipino ang tunog.. May increase pa sa hp.. And mas malamig temperature NG radiator mo... NASA 6k Lang ginastos ko...
    Feb 2012
    Anu ginawa mo sir?
    May 2012
    Ano ginawa mo sir glenn?
    Jun 2011
    I replaced the OEM clutch fan with an electric type aux fan... Ginamit ko aux fan ng pang Tucson bnew nasa 4.2k Lang... May high and low speed, nilagyan ko nalang ng relay, high and low.. Then auto on yung low... Yung high may switch.. You don't need to use high... Ginagamit ko Lang pag gusto kung palamigin agad aircon...
    Honestly, I didn't expect before Na, mas lalamig aircon... Or mas gagaang tumakbo... I converted it para Lang matangal ko yung ugong ng mb100 Na van... Yung noise level ngayon comparable Na sa bagong hiace...
    Feb 2012
    Hindi yata gagana sa pag palamig ng ac ko yan sir kasi parehas na nasa ilalim dalawang condenser ko converted ng dating may kanya dati kasi nag oovrerheat kaya siguro inilipat
    Pero sa takbo at noise level tsak yun tatahimik siguro kaso sir baka di kayanin ng alternator ko? Kasi dalawa na blower nung Yokohama na evap tas yung auxfan pa ng dalawang condenser tapos 4 ang headlight ng grace ko hehe baka masunugan na naman ng IC hehe
    Jun 2011
    One of the reasons why I experimented on this is because... What we noticed kasi pag nag remote type kami ng Radiator sa malalaking Generator sets using an electric type fan.. Una nawawala ugong... Then 2nd yung 1500kva namin Na genset when load tested can easily reach 100% of its load rating and can even reach up to 120% without over heating... And 2nd may Naka try Na din kasing isa kaya ginamit ko yung same Na aux fan Na ginawa nya...
    Actually Na test drive ko Na din yung old mb100 van ko at 5th gear naka 5100rpm... Without overheating, hindi ko din kailangan bombahin ang silinyador, hindi din ma usok... No modification sa engine all stock..
    Feb 2012
    Tapos sir paano naging 3 ang evaporator mo? Pano ang connection nun? Anu comp gamit mo kasi yung akin Nippon denso
    Kakayanin kaya din nung akin?
    Jun 2011
    Quote Originally Posted by sotel View Post
    17C ang oem Na compressor ng mb140 Kaya nya tatlo evaporator... Yung connection nag Y connection Lang sa Taas sa gilid...
    Modified Na kasi evaporator ko... Click image for larger version.
Name:	ImageUploadedByTsikot Forums1438418226.110557.jpg
    Ito yung pic. Click image for larger version.
Name:	ImageUploadedByTsikot Forums1438419042.564735.jpg
    Attached Thumbnails Attached Thumbnails imageuploadedbytsikot-forums1438418435.238202.jpg
    May 2012
    AFAIK, Orig talaga ng mga mb vans 3 evap..
Hindi nag automatic compressor
