Results 11 to 20 of 35
May 4th, 2007 10:33 AM #11
sa init ngayun ilan seconds lang tuyo na yun water na spray nito. i'll just go with the constant cleaning/inspection of my condenser. but what the heck if it works then good. sira pala aircon ng tsikot ko now. ang init sigurado paglabas ko mamyang 2pm.
May 4th, 2007 07:32 PM #13
wrcastro: no, why should it... aluminum yan eh.
if your ac doesn't cool even with 80kph, your aux fan needs replacement hehe.
- May 2006
- 1,668
May 5th, 2007 08:54 AM #16
ok. di ko nakayanan ang init so after work 2pm diretso ako sa aircon shop sa marikina, well lower antipolo na pala yun, sa bankers aircon. yun receiver dryer ko barado, pumutok yun isang hose, then nun charge na nila freon yun blower sa harap walang lamig yun likod lang, ayun palit expansion valve sa harap. buti may freon recovery thingie contraption sila. lamig na ngayun unlike nun bagong linis lang. keep your system in top shape para di na ninyo need maglagay ng spray sa harap ng condenser.
- Apr 2009
- 1,902
May 31st, 2010 12:43 PM #17Tried to DIY this last weekend. Dali lang siya.
Question lang po, pag yung nozzle ng water spray bottle po ba yung kinabit niyo sa dulo ng hose automatic pakalat na yung buga ng tubig niya?
Yung nagawa ko kasi hindi pakalat yung buga ng tubig pero dinikit ko na yung 2 hose sa mga fin ng condenser.
Di po ba mas effective ito pag pakalat yung spray (yung tipong pressurized) ???
- Apr 2009
- 1,902
May 31st, 2010 12:56 PM #18Pano po gawing wide spray? Pag dinikit po ba yung nozzle dun sa hose automatic wide spray na?
Yung atomised/pakalat na spray po diba kelangan pa ng pressurised air para maging pakalat yung buga?
Yung nagawa ko po kasi hindi pakalat yung spray eh.
Thanks.
- Apr 2009
- 551
June 1st, 2010 12:24 PM #19its a good idea, puede pala yung wiper washer pambuga.
ako naman if nasa house lang at paalis ako spray ko water condenser. kung basang basa na then i open the aircon yun lamig naman agad.
another way naman is to add aux fax. may nabibili yung manipis lang lagay mo sa harap ng condenser everytime compressor is On sabay ang aux fan.
it helps a lot. yung crosswind ko ganun naglagay ako sa harap isa nga lang. maybe someday gawin kong dalawa. sa battery naman does not affect much i tested it with my voltmeter.parang ilaw lang
- Apr 2009
- 551
June 1st, 2010 12:26 PM #20its a good idea, puede pala yung wiper washer pambuga.
