Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 54
    Sep 2013
    #41
    for me its:
    1> turn on engine
    2> turn on blower
    3> if mainit sa loob, open windows for a minute or two.
    4> turn on the compressor, via thermostat. walang a/c button yung fx eh.
    i do this to let the engine spray itself with oil, so when i activate the idle up system via thermostat its less wear and tear.
    pag ioff naman engine, off muna compressor via thermostat pagdating sa bahay then off ng blower then engine after parking the vehicle. opening the gates, vehicle entry, gates closed, that takes a minute at least. by that time tuyo na evaporator. =)
    its more of taking care of the engine (start up) and the vehicle itself (iwas amoy mabaho/kulob).
    Sep 2013
    #42
    double post....
    Jan 2009
    #43
    I turn on the A/C (fan and compressor) even on cold-starts. The extra load will actually speed up the engine warm-up. Also, the slightly elevated idling will help increase oil pressure to get them moving.
    Aug 2012
    #44
    hindi ba ito masama?
    Jan 2009
    #45
    Quote Originally Posted by chard23 View Post
    I see no reason. The only thing to remember is, dapat mag idle-up. If by turning on the compressor, the extra load is instead dragging the engine to a lower RPM when the engine is still cold, then stop doing it.
    Apr 2013
    #46
    Assuming your ac unit is working perfectly,kelangan bang I palinis at kung yes,kelan dapat,yearly,2 years?
    #47
    Mga newer cars Hindi na dapat nag cleaning ng ac system. Kaya may cabin filter na. Para mafilter yung mga dumi. Just change the filter every so often. Kaya usually baklas dashboard na mga cars ngayon kung kailangan mag cleaning. From design niya kasi filter changes nalang dapat.
    Posted via Tsikot Mobile App
    Jul 2011
    #48
    Kabitan ng turbo timer ang blower, para pag off mo ng engine ung blower running pa din ng ilang minutes
    sent via LaTE Network
    Oct 2009
    #49
    Saan mas malakas ang effect ng fuel consumption, Sa high thermostat adjustment to cool, Yung high fan or both. Thanks.
    #50
    Quote Originally Posted by povillo View Post
    i believe the power drain in running the compressor, outweighs any electrical drain the fan motor can think of.
A/C proper usage
