Results 11 to 20 of 106
July 31st, 2013 03:51 PM #11
Takot kasi ako ma mess up settings or whatever ng Altis.
Sent from my GT-N7100 using Tapatalk 4 Beta
July 31st, 2013 03:59 PM #12
they won't mess up anything
they'll just hook up a gauge to find out if the freon is low
if confirmed pakargahan mo. it's around P600 lang
don't let them do anything else kahit sabihin nila kailangan cleaning etc
- Jan 2008
- 4,726
July 31st, 2013 04:07 PM #13malamang may singaw yan somewhere....
kaya i don't use that auto climate ek ek eh.. kasi stressed yung compressor kasi tuloy tuloy lang takbo nyan.. mag disengage lang yan when the evaporator reach -5 degrees or when the ecu senses that you need extra power.. desired cabin temp is achieved by mixing hot and cold air.. unlike sa conventional na thermostat na pag na reach yung certain temp, mag disengage yung compressor
July 31st, 2013 04:10 PM #14
July 31st, 2013 04:46 PM #15
doon muna tayo sa best case scenario -- freon lang. the leak is probably so slow it's negligible. kargahan ng freon and the cold will last (that's my bet)
ayaw mo kasi ipagalaw eh
so the most you can do is karga freon
July 31st, 2013 04:55 PM #16
July 31st, 2013 04:56 PM #17
Check freon muna. Kung may leak hahanapin naman nila yan. Tapos pacheck mo na rin ibang components like evaporator, condenser, expansion valve
Sent from my GT-N7100 using Tapatalk 2
July 31st, 2013 04:56 PM #18
Do you still hear the compressor kick in? Is it turning? Do all aux fans run at high speed when it does?
