Re: index ng common na sira ng kotse
May kulang sa COOLING SYSTEM
Quote:
40. Engine overheats.
a. Insufficient coolant.
b. Coolant system leaks.
c. Incorrect belt tension.
d. Defective thermostat.
e. Cooling system passages blocked.
f. Defective fan blade.
g. Defective water pump.
h. Defective auxiliary fan (if electric motor driven and if available).
Addition ko pa ulit
Quote:
84. Hard steering.
a. Incorrect tire pressure.
b. Tires not of uniform
c. Lack of lubrication.
d. Incorrect steering gear adjustment.
e. If power assisted, insufficient ATF in power steering fluid reservoir.
f. Incorrect power steering belt tension.
g. Defective or leak in high pressure line.
h. Defective power steering pump.
nice thread.buti nabuhay ulit.
useful indeed.........thanks:yes:
well done mga sir!:bowako: this will be a good help!:nod:
dami pala pwede masira sa sasakyan ko. ipon nako pambayad:help:
i agree. . .sticky thread 'to. . .
maraming salamat, bro. . .
Nice thread. Very helpful and informative. :bowako::bowako::bowako:
this info is very helpful especially for those who don't know much about the intricacies of the automobile. I copied it for my own personal reference. Thanks
thanks sa thread na ito...sana madagdagan pa at pwedeng gawing mas detailed (like kaibahan ng automatic at manual pagdating sa Engine will not crank)... keep it up!
