Results 1 to 10 of 11
September 26th, 2009 06:56 PM #1
Just wanted to share......
Ever since mabili ko yung 2nd hand na sasakyan ko, it has these problems sa front windows nya:
1) Front driver window does not allign when rolled all the way up. May gap and although hindi naman masyadong malaki, nakakairita pa rin. I just open the doors when paying the toll or parking.
2) Front passenger window only rolls half the way down. No big deal since bihira ko sya ibaba.
Had my power window mechanism checked and found it working properly. Yung rubber window siding ko daw ang kailangang palitan para ma-solve yung problems specified above. I decided to live with it na lang since hindi worth it yung gastos.
While waiting for the wife in SM this stormy morning, I decided to check Ace Hardware. Saw this Power Window Lubricant by Elevo. 110ml costs P130. I decided to give it a try..... lo and behold..... na-solve nya both my front window problems...... bale i-apply mo lang sa rut nung window.... sa mismong rubber siding na tinatakbuhan nung window.... bumilis din ang pag taas-baba nya....
September 26th, 2009 07:17 PM #2
I have also that Elevo power lubricant and smooth gliding on your window. It lubricates stuck windows and good also to rubber and vinyl.
Tsikot Member Rank 3
- Jul 2004
- 1,540
September 26th, 2009 07:26 PM #3wow. this is big help. thanks!
Kasi when I had ours fixed, sabe use armor all daw.
I guess this would be better since pang power window talaga.
September 26th, 2009 07:28 PM #4
gamit ko sa window channels para smooth ang travel ay iyong silicone spray. effective din iyon
September 27th, 2009 08:24 AM #5
Salamat Macky for sharing.
Subukan ko yang Elevo Power Window Lubricant.
i had the same problem with my Jazz because the rubbers of the windows were so sticky, napwersa ng motor yung guide & natanggal yung rubber.
September 27th, 2009 12:42 PM #6
Thanks for your post TS. Problema ko din ito. Yung window ko naman gumagasgas sa rubber. Subukan ko bumili ng lubricant
- Feb 2009
- 171
September 29th, 2009 05:42 PM #7Nasubukan ko na yang lubricant na yan kasi problem ko din yan dun sa passenger side na window nilagay ko yung lubricant sa gilid dun sa may rubber part tapos tinaas, baba ko yung window tapos nilagyan ko ulit hangang sa yun ok na effective naman. You need a few tries para gumana don't expect that it will do its job instantly in one application
Goodluck!
September 30th, 2009 04:54 PM #8
Naka bili ako kanina. Gumanda yung taas nung driver side windows. Magmula kasi nung na overhaul and napalitan motor di na sya tulad nung dati. Pero after ko lagyan kanina medyo effortless na sya. I believe give it mga 2-3 days para lalo ma lubricate mabuti yung rubber and makita effect nito. Pag alis ko mamaya check ko pero so far satisfied ako. Thanks bro!
October 21st, 2009 08:31 AM #9
Double check lang mga friend. Just bought said Power Window Lubricant, pero di ko pa inaaply. Tanong lang muna sana. Bale dun mismo sa rubbers ilalagay yung lubricant right? So papahid din yung lubricant sa glass pag tinaas/baba na yung window? Di po ba nakakasira ng tint sa glass??......hehehe, sensya na if weird yung question ha. Nagsisiguro lang, baka mamali me ng pag apply e..ehehehe.
Salamat
October 22nd, 2009 10:20 AM #10
Wala namang pangit na tanong talaga if ang motive is matuto hehehe at yes po, dun mismo sa rubber siding ia-apply yung lubricant para smooth yung daan ng glass window. Pag di kasi lumapat yung glass... di na sya matatawag na lubricant since wala nang ilu-lubricate... So far, after almost 1 month, ni-check ko yung glass ko and ok naman yung tints (isa pa is as long as maganda pagkakakabit ng tints mo, di sya basta basta masisira).... pati siguro yung dust particles dumudulas din... which is, come to think of it, yun kasi ang function talaga ng lubricant :-) Pero f in doubt ka pa rin, you could always pull out the door covers and linisin mo muna yung gilid ng windows mo. Linisin mo na rin yung rubber sidings na dinadaanan nya.
