Results 1 to 10 of 10
    Feb 2017
    What will happen I use longer wiper blades
    Sep 2005
    ok lang basta hindi lalagpas sa windshield mo.
    Feb 2017
    Quote Originally Posted by danegoesonline View Post
    Mas hirap ang wiper motor to wipe bigger wipers. Not spec wise
    If the wiper motor life is 500hrs (operational), this will be reduced with the bigger load...
    Jul 2013
    yup... basta walang tatamaan.
    Ako dati (using refills) medyo an inch longer...
    I always do this when the time comes to replace wiper blades, i always get the next bigger size. No issues whatsoever. Mechanical parts always have a factor of safety and parts like this will have at least n = 1.25. A 1 or 2 inch increase in wiper length should not increase forces more than that 25% allowance.
    baka may tamaan.
    you can wet your windshield, and run the wipers. you can easily see the area of wipe. that way, you can get an idea of just how much bigger you may do, without the blade hitting something.
    Feb 2017
    Yung blade b dpt sakto dulo dulo o tlgng my sbra
    Sent from my SM-G532G using Tapatalk
    Meron sizing chart sa ace..
    It will wipe a larger area.
Is it ok to use longer wiper blades?
