Results 1 to 10 of 10
    Sep 2011
    I need to put a 2" x 12" sticker on the rear glass.
    Aug 2004
    Measure off the spot you're putting it on with tape first.
    Quote Originally Posted by Harangody View Post
    You could ask tint installers to help you. At least with their method, you can still adjust the sticker to properly center it.
    Jun 2010
    spray shampoo with water
    Feb 2009
    use a sacrificial material like plastic film and fold it in half-this way you get the center if that's where you need it placed. then mark with a white board marker to mark the center. install the film sticker one side at a time just like what you do with "band aid". roll the tape a little at a time pushing out bubbles. if the film is not elastic enough, use a hair blower to warm the material and shape it to the surface you want it installed while the backing of the sticker is still on.
    baka problema rin ni TS on how to stick the sticker w/out the "kulubot".
    kasi, pabilog yung surface. ang sticker maganda lapat pag flat yung surface.
    i don't know kung isa yan sa issues nya......
    That is why its probably best to ask the help of some tint installers.
    Feb 2010
    Put a markings on where you will place the sticker, spray the surface with shampoo mix with water, place the sticker while surface is still wet so you can move the sticker evenly and in place with ease. Let it dry, then wipe with clean smooth cloth. That's all.....
    Sep 2011
    Quote Originally Posted by Joe Magarac View Post
    Thanks! This worked.
    Thanks rin sa replies ng iba.
    Jan 2008
    yan din naman gamit ng mga tint installers.... use shampoo mixed with water....
How can I place a long sticker on a round surface accurately?
