Page 8 of 8 FirstFirst ... 45678
Results 71 to 79 of 79
    Mar 2005
    #71
    I'd recommend a claybar. But keeping all your wiper blades clean is a must also.
    Dec 2017
    #72
    Quote Originally Posted by Bravoexo View Post
    May I know if you have tried using that on your windshield? I had a hard time removing those nasty marks yesterday using Stainz Out. Although it is no longer visible, I can still see it. I already applied Stain Guard as I got tired rubbing it.
    Alam nyo ano tawag dito at saan nabibili ito gamit nya pang scrape ng sticker sa glass.
    Fast forward 6:32
    Mar 2004
    #74
    The ones being used locally are the same as what painters use ... There's a plastic and a metal version ... Paint scraper tool ...
    walty, thank you sa description mo. Nag-inquire ako ang sinuggest sa akin kung gagamtin ko sa glass window eh yung rubber squeegee daw gamit sa silkscreen. Punta daw ako national bookstore.
    May 2018
    #76
    Pantangal ng sticker ba? Blade lang nung old style* na pangahit tapos gas lang para matangal yung lagkit.
    *Yun bang ginagamit ng barbero na disposable pang ahit ng patillya na individually wrapped.
    Sep 2018
    #77
    I suggest you can use Invisible Glass for Glass Cleaner on your car. It can be use for both glass panels or windshields. I personally like it since it doesn't leave any marks or streaks. It can be use for both outside and inside surfaces of the glass.
    Feb 2015
    #78
    I use "Rain-X 2-in-1 Glass Cleaner+Rain Repellent" after I parked my car when it rains. Because water marks are so much harder to remove in glass than paint.
    Nov 2007
    #79
    Quote Originally Posted by SoleusBB View Post
    Ahit “Rubie”
Glass Cleaner
