Results 11 to 20 of 28
- Jan 2009
- 8
April 2nd, 2009 12:51 PM #11The turbo here in the U.S. on XC90 2.5T is made by Mitsubishi turbo. They rarely go bad. So whats wrong with your turbo, send me e-mail on the diagnosis on your turbo.
- Jan 2009
- 8
April 2nd, 2009 12:58 PM #12Is the check engine light on? Any codes? Are the S40s in the PI turbo charged? If it is, check if the turbo is functioning, check number 3 and 4 coil for sign of crack in the housing causing the engine to misfires. Also, for the vibration, check the right hand side engine mount and the transmission mount, they tend to go bad a lot and we've been replacing a lot of those. If you need parts for your Volvo, tell me what parts you need because I ship parts to the PI. Ill give you the name and address where to purchase it from in the PI. Sorry for the late reply, I've been caught up at work. Ill be posting pictures of the new XC60 with the video of the city safety that stops by itself. Its really cool
- Jan 2009
- 8
April 2nd, 2009 01:14 PM #13Actually, the engine and transmission on the S40 and 850 are identical. The only difference is that there is one cylinder less on the S40. But problematic no. The S40s are built in Belgium and the parts are reliable and available here in the US. I actually have a 2001 V40 with 90,000 miles and I never had problem with this car and I love this car. Also, if you need any parts, I can get you some cheap used parts. Ill ship it to the PI from here. Sorry again for the late reply, I haven't checked my e-mail and I've been caught up at work.
- Nov 2008
- 30
April 2nd, 2009 02:27 PM #14
- Nov 2008
- 30
April 2nd, 2009 02:32 PM #15
- Jan 2009
- 8
April 2nd, 2009 03:06 PM #16first check for a faulty fuel pressure regulator. the easy way to check is to disconnect the small vacuum hose attached to the regulator for fuel leaking fr. the hose,if u see fuel coming out fr. the hose this means diaphram fr. reg. is leaking.
- Jan 2009
- 8
April 2nd, 2009 03:11 PM #17hey guys, you can clean throttle body and idle motor but dont touch the inside of the MAF sensor very critical.
- Nov 2008
- 30
April 2nd, 2009 03:57 PM #18
- Jan 2009
- 76
April 3rd, 2009 04:46 PM #19Someone PMed me that it is the pre 2001 S40 that is problematic. As for the 850, there seems to be a consensus that it is more durable. This is not to dispute your post but hope you can shed more light.
Maybe you can post your contact details for the benefit of readers.
- Jan 2009
- 8
April 6th, 2009 06:40 AM #20hi guys, the 40 series here starts in the year 2000 and up. Looks like you guys have earlier models than that. Are those Volvo engines or Mitsubishi engines, because I heard the early ones are.
