Results 1 to 7 of 7
    Quote Originally Posted by semimaru30 View Post
    Sir,
    The Carb is leaking gas. Its coming out of the carb itself. May mga nakita ako sa youtube na ang sabi it has something to do with the float.
    It could be the float. But once it happens, your engine will definitely stall. But based on your description above, you're still running, which means your carb's not yet overflowing. I suggest you remove the air cleaner then start your car, and look closely where the leaking gas comes from. Check all fuel lines connected to the carb, specially the fittings and fuel hoses. Check also the sections of the carb, specially the gasket connected areas. If there's a sign of gas, then the gasket should be replaced.
    Jun 2009
    Check the fuel supply line that connects to the carburator from the fuel pump maybe its loose or worn out
    the air-cooled beetle's carburator is notorious for causing leaks and fires.. because, and you said it, it is located over the distributor.
    problems could be in the float adjustment, and/or in the poor condition of the gasket. both are easy to fix.
    or, the carb top is already deformed by excessive tightening of the screws..
    a perished and leaking fuel hose (as it inserts over the carb inlet tube) is also to blame sometimes.
    either way, they are signs of a neglected beetle.. heh heh.
    good luck.
    Big problem but hope it would be fixed soon...
HELP! VW Beetle Leaking Gasoline
