Results 261 to 270 of 774
- Oct 2013
- 2,537
February 12th, 2014 05:00 PM #263
May 23rd, 2014 10:18 AM #264
Ayaw talagang bumitaw sa current NAIA....
Gov't allots P2B for new parallel runway | ABS-CBN News
By Lawrence Agcaoili, The Philippine Star
Posted at 05/23/2014 8:00 AM | Updated as of 05/23/2014 8:00 AM
MANILA - The government is initially spending at least P2 billion to put up an alternative runway parallel to the existing runway to ease traffic congestion at the Ninoy Aquino International Airport (NAIA).
Transportation Secretary Joseph Emilio Abaya told reporters on the sidelines of the 23rd World Economic Forum (WEF) East Asia that the first phase of the project would involve the construction of a 2.1-kilometer runway parallel or south of the existing primary runway 06/24.
“The first phase is P2 billion but we have to verify that. The new runway could allow Airbus A320 to land,” Abaya said.
According to him, the government would have to study the proposed runway as this could displace close to 600 houses in the Merville Subdivision beside the 400-hectare NAIA complex.
“Probably our biggest challenge is the 600 households that will be affected. We’re still verifying if they are informal settlers or private owners. I think at the end of the day that’s going to be the biggest challenge,” Abaya said.
Since the project would involve expropriation of land and relocation of families to be displaced, the DOTC chief said the agency needs the help of the Department of Public Works and Highways (DPWH) as well as the National Housing Authority (NHA).
“The plan is the government will finance the relocation. So we need help from DPWH and NHA since we are not an expert in relocation,” Abaya added.
Another concern, he added, is the possibility that the International Civil Aviation Organization (ICAO) could withdraw the certification of the existing runway once a new runway is constructed beside it.
“We’re also checking with ICAO. They are saying that when you have a precision landing certified runway and if you construct a new runway beside it the existing certification will be cancelled. We don’t want this to happen,” he said.
The DOTC chief said he has tasked the Civil Aviation Authority of the Philippines (CAAP) to check with ICAO so as not to compromise the certification of the existing runway.
He pointed out that the idea of constructing a new runway came from diversified conglomerate San Miguel Corp. (SMC) which also owns national flag carrier Philippine Airlines Inc. (PAL).
Abaya said SMC and PAL argued that the Los Angeles Airport has a similar set up of parallel runways.
He added that the additional runway would increase the landings and take-offs at the congested international to between 60 and 70 events per hour from the current 40.
The NAIA was built in 1981 with two intersecting runways – primary runway 06/24 and secondary runway 13/31. Aviation authorities to cap the number aircraft movements at 40 per hour as it decided to move general aviation flights to the Sangley airport in Cavite
“Familiarity breeds awe”
23.2K:veiledsmile1:
May 23rd, 2014 11:11 AM #265
:old::old::old:
asa pa tayo..hanggat may mga politikong suwapang at ganid sa posisyon hindi talaga uunlad ang bansa. bago nila pag tuunan ng pansin yaan edie sarili muna nilang bulsa ang iisipin nila. dapat nga kung talaga gusto nating maging isa tayo sa world class airport dapat ayusin at pagandahin mga facilities kaso dahil sa kurapsyon e malabo tayong maging world class..
May 23rd, 2014 11:21 AM #266
No wonder the WEF was a total laughing ground for delegates. Puro yabang ang mga officals natin, puro reverse naman ang result. Tulad nito, pinagyabang pa instead of new airport na lang. Dagdagan man ng parallel run way, uurong yung skyway tapos yung parking ng eroplano eh napasikip na with in the airport terminal itself. Wala pang terminal bridge to accommodate A380. Useless proposal as to who ever came up with an idea.
May 23rd, 2014 11:30 AM #267
Besides, they have to maintain NINOY AQUINO name kaya ayaw pa ilipat ang airport.
May 23rd, 2014 11:45 AM #268
The proposed new parallel runway is deemed to close to the old one... it is only 260m distance between the 2 centreline.
I hope the goverment is not doing this just to please BS Aquino's ego...
http://www.uecna.eu/spip.php?page=article&id_article=16
CAO Annex 14 Recommendation, is reflected in EASA draft Certification Specifications, CS ADR-DSN.B.055, as follows:
CS ADR-DSN.B.055 Minimum distance between parallel instrument runways
(a) Where parallel instrument runways are intended for simultaneous use, the minimum distance between their centre lines should be:
(1) 1 035 m for independent parallel approaches;
(2) 915 m for dependent parallel approaches;
(3) 760 m for independent parallel departures; and
(4) 760 m for segregated parallel operations.Last edited by Monseratto; May 23rd, 2014 at 11:56 AM.
May 23rd, 2014 12:10 PM #269
May 31st, 2014 11:53 AM #270
Airconditioning at NAIA T2... ACU used on planes now used for the terminal...ano ba yan???
Tesla Philippines
