Results 1 to 8 of 8
March 23rd, 2015 07:24 PM #1
Hello po,
Merun pong tog sound when i release the clutch on 1st 2nd or even 3rd gear parang tunog jack rabbit. Na test ko rin po from full stop and 1st gear ko din dahan dahan release ng clutch (walang gas na apak) before ma full release ko yun clutch merun din "tog" na sound. Anyone encounter same issue? Any idea anu po yun sira?
MAraming salamat po.
- Jan 2015
- 468
March 23rd, 2015 08:53 PM #2normally pag ganyan, either release bearing or pressure plate. maybe both.
anong oto at when napalitan ng clutch?
- Jan 2015
- 468
March 24th, 2015 10:20 AM #4ahh clutch na nga iyan, walang duda.
wag mo na pagalin baka madale pati gearbox mo.
after clutch replacement, palit gear oil ka na din, Sir
March 24th, 2015 10:53 AM #5
i agree that it has to be the clutch.... na experience ko na din yan eh.
- Oct 2009
- 2,271
March 24th, 2015 02:53 PM #6minsan engine support din..
malakas ba ung tog sound
March 25th, 2015 11:44 AM #7
medyo sir may kalakasan tunog.
March 27th, 2015 04:55 PM #8
False alarm! ngpalit ako front shock without replacing shock mount dito ko napansin malakas yun tunog. sinabi sa akin ng mechanic na palitan din daw yun mounting. once nakahanap at nakabili ako pinakabit ko mounting nawala yun tunog.
pinadouble check ko sa mechanic wala naman daw prob yun clutch ko.
False alarm! ngpalit ako front shock without replacing shock mount dito ko napansin malakas yun tunog. sinabi sa akin ng mechanic na palitan din daw yun mounting. once nakahanap at nakabili ako pinakabit ko mounting nawala yun tunog.pinadouble check ko sa mechanic wala naman daw prob yun clutch ko.
Tesla Philippines
