Results 1 to 10 of 12
goldrat starter solenoid failure June 27th, 2024, 09:24 AM
H1Tman Re: starter solenoid failure June 27th, 2024, 10:33 AM
oj88 Re: starter solenoid failure June 27th, 2024, 10:45 AM
ice15 Re: starter solenoid failure June 27th, 2024, 10:53 AM
oj88 Re: starter solenoid failure June 27th, 2024, 10:59 AM
ice15 Re: starter solenoid failure June 27th, 2024, 11:50 AM
dr. d Re: starter solenoid failure June 27th, 2024, 12:25 PM
goldrat Re: starter solenoid failure June 29th, 2024, 10:38 PM
    May 2008
    I am posting this here. The starter on my 2009 city failed and was replaced with a surplus unit. I asked the mechanic why the solenoid could not just be replaced to save the starter motor. The reply was that the solenoid and starter motor came as a unit. Anybody care to comment?
    Apr 2005
    Kung napalitan na at it's working fine, I don't think this will matter. But keep the original and have it repaired at Yocks, for future use.
    Jan 2009
    Since you were buying a used part, it's not worth the trouble just transferring the solenoid. As long as the replacement starter motor is good, just replace the whole assembly.
    The solenoid is essentially one with the starter. Aside from its job of switching high-current, it also moves the pinion gear towards the flywheel when it becomes energized. Transferring just the solenoid could mess up something else inadvertently and the whole mechanism could fail.
    Jul 2013
    in the old days... the solenoid can be replaced.
    pero honestly, di pa ako nakakakita ng starter ng "modern cars" and I'm not sure if its worth the time and effort to "repair" a broken starter.
    Jan 2009
    Starter motor assemblies are intrinsically very reliable and lasts a very long time. Oftentimes, it would last the life of the car. If they do fail, there are plenty of them available in the used market.
    The only time you may want to consider repairing is when it's a rare part, such that if it came from a vehicle/engine that was imported but never sold locally.
    Jul 2013
    personal experience ko sa FX (2C engine) - every time tinatamaan ng flood water yung starter, nasusunog sya
    Jan 2009
    Growing up in the 70's and 80's in my dad's talyer, I recall seeing customers occasionally come in with problematic starters. I guess back then, starters were more taxed because engines only had carburetors and more often than not, they will not start on the first 'click'. Carburetor issues, problems with the distributor cap (contact points, condenser, timing, etc.) or the high-voltage systems (hi-tension wires, ignition coil, etc.), all worked towards a hard-starting engine.
    Modern engines with EFI and ECM/PCM, made it more likely for the engine to start on the first try. I think that and other technological improvements to the overall engine and starter design, including engine mass and weight reduction, etc., lends towards their increased reliability nowadays.
    Quote Originally Posted by goldrat View Post
    to clarify,
    did the starter fail, or did the solenoid fail?
    they's two different items, sharing a common assembly.
    i do not know about your car's solenoid-only repair-ability,
    but when my non-honda solenoid failed, the mechanic just replaced the solenoid.
    the choice probably will also depend on the price difference between brand-new solenoid-only replacement, versus starter+solenoid assembly surplus replacement.
    one thing i will avoid if i can: repair the solenoid. in my view, it's a replace-only item.
    May 2008
    to clarify,
    It was the solenoid that had failed. the mechanic's claim was that the solenoid cannot be replaced/unavailable. i have also checked with some Honda part sites on the web and the solenoid/starter motor only comes as an assembly. there was no part number and separate pricing for the solenoid itself.
