Results 1 to 10 of 16
- Feb 2017
- 28
March 4th, 2017 01:07 AM #1What is likely affected when you're in reverse and slowly release the clutch then you starts moving forward because its a downhill, around 10 meters , my screetching sound habang umandar. After that incident anu kaya ang tinamaan?
- 53,883
March 4th, 2017 08:42 AM #2
- Dec 2013
- 680
March 4th, 2017 09:25 AM #3The way i understand it, the driver was slow to shift. When he finally gets it into reverse, the car was already rolling forward because of the incline. Methinks the screeching came from the wheels suddenly jerked into reverse while going forward.
Sent from my LG-D855 using Tapatalk
- Jul 2016
- 939
March 4th, 2017 09:36 AM #4
- Feb 2017
- 28
March 4th, 2017 09:42 AM #5Hi sorry mga sir medyo magulo nga. Umatras kasi ako noon going out sa parking na inclined, so nung naka atras na nag clutch na ako while still in reverse making the car move forward but forgot to shift to 1st gear.
So while naka reverse i was slowly releasing the clutch while moving forward on the steep inclined, i heard screetching.
I's suspecting pambelt becuase it sounded like one, but some article are point to trans and engine. About 5-10 meter yun tinakbo niya before ko narealize na nakareverse.
- Feb 2017
- 28
March 4th, 2017 09:46 AM #6Actually it was my girlfriend who was driving then. Medyo tinuturuan ko pa and we both failed to notice right away.
- 53,883
March 4th, 2017 09:49 AM #7what comes to my mind that causes such screeching sound:
1. idler pulley needs lubrication. now, we know that lubricating it is just a first aid measure. replacement is the long-term solution.
2. fanbelt slippage. maluwag... nabasa... service it only. no need to replace, unless it already shows cracking.
3. smokin'tires! but i don't think this is your cause.
- Feb 2017
- 28
March 4th, 2017 10:04 AM #8
March 4th, 2017 10:11 AM #9
The clutch shouldn't make that noise. My guess is that what you heard was the belt. It was just pure coincidence that the noise appeared while you're still in reverse and moving forward.
BUT, if you were already coasting downhill for 5-10 meters, there would've been enough build up of speed for the tires to squeal when you released the clutch while in reverse.
- 53,883
March 4th, 2017 10:22 AM #10
Tesla Philippines
