Results 1 to 10 of 15
November 8th, 2006 06:45 PM #1
guys i need your inputs on this... my car as reflected sa profile ko is a 95 corolla.
meron long time problem yung clutch ko. before napalitan ko ng 2 replacement and 1 original. napalitan na din yung secondary assembly.
a few months lang yung tinatagal ng replacement pati nung 1 original na pinalit ko. sa lahat ng parts na pinalit din (kasama original) nagkukulay black yung fluid reservoir. and nung last na palit meron konti oil residue na kasama sa fluid. di ko alam kung paano nasamahan since wala naman di ba ibang parts na nakakabit sa transmission system.
opinion ng mechanic na kausap ko buksan daw yung transmission baka andun yung problema kasi pati yung original nasira agad.
yung first replacement na kinabit ko pala lasted more than a year. and habang tumatagal paikli ng paikli yung lifespan ng assembly. di ko nga din maintindihan bakit pati yung original nasira agad.
any opinions? ano kaya problema sa system? parts? mechanic?
or owner?
November 8th, 2006 06:59 PM #2
are you sure your clutch line doesn't go anywhere else
November 8th, 2006 09:10 PM #5
well, i know why it does that. ang problem ko is baket pati yung original toyota part ganun nangyari sa akin and in just a few months at that.
btw, galing yung black color is caused by the rubber sa loob ng clutch master assembly.
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 8th, 2006 10:12 PM #6check if everything is aligned correctly. baka may kayod yung pedal kaya lagi nasisira agad.
November 9th, 2006 10:45 AM #7
Buong clutch master assy po ba ang pinalitan or Piston lang? Kasi kung piston lang ang pinalitan malamang sira na yung clutch master cylinder magaspang na yung loob or matalas kaya nasisira kaagad yung seal kaya nangingitim yung fluid.
November 9th, 2006 03:17 PM #9
nag-bleed ba ng fluid after mapalitan yung clutch master assembly para malinis yung buong system? tapos orig ba kaya talaga yung ipinalit? marami na kasing nagkalat na orig "kuno" na toyota parts gayang-gaya yung packaging.
November 9th, 2006 11:56 PM #10
Wow nasira kaagad? Nung binili ba yung pyesa nasa loob na ng cylinder yung piston? as in whole package yung dating?
Tesla Philippines
