Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Sep 2013
    something odd happening in my sedan MT is not smooth shifting. Checked & observed the ff
    1. no leaking
    2. replaced the fluids already 5 months ago
    3. no burning smell
    4. no gears slipping but sometimes, it's difficult to shift into reverse gear.
    what do you think is the cause of a problem or defect??
    Sep 2008
    Quote Originally Posted by kimbon View Post
    1. no leaking
    3. no burning smell
    Most likely a clutch problem, what is your mileage? It could be either the clutch slave or the clutch disc/pressure plate
    1. no leaking
    3. no burning smell
    Sep 2013
    ^^ 41k mileage. at saka pansin ko medyo stiff na rin ang clutch pero manageable pa naman. never pa naibaba ang clutch nito..
    Sep 2008
    your mileage is so small para maging clutch disc/pressure plate problem unless you are a clutch driver or something extraordinary is wrong with it. I would rule it out, so I would like to think it is a clutch slave issue. Baka naman all it needs is a little adjustment sa clutch lever to make shifting smoother. Mababa ba ang clutch?
    Jan 2011
    shifter bushing, baka pudpud na. it is made of plastic. around 50 petot/pc yata. usually palitan mo 8 pcs. just have it check pag medyo sumasabit. madalai lang ikabit po yan sir. you can even have it DIY, kung yon nga ang culprit.
    Sep 2013
    Quote Originally Posted by jakewise View Post
    di naman mababa or mataas kundi nasa gitna lang. di pa ito na-adjust or nagalaw since nabili ito ng brandnew
    nope di talaga ako clutch driver. kung minsan nga nanginginig na ang makina saka ko pa lang press ang clutch pero bihirang bihira lang ito mangyari. hehe
    Sep 2008
    if you are sure na walang leakage including where the clutch slave is located, you might need to check the internals ng clutch slave, baka ang rubber cups ay malambot na. There is a repair kit for that
    Sep 2013
    Quote Originally Posted by shelu View Post
    shifter bushing? saan ko kaya makikita ito sa pang-ilalim o sa loob rubber boots ng kambio? nasa youtube DIY ba to? TIA
    Sep 2013
    yup talagang walang leak. kapag umaalis ako sa parking ko i check yung floor kung may tagas na any fluids. tubig lang galing sa a/c
    1. no leaking
    3. no burning smell
    What is the make and model of your car?
    You mentioned that you changed the transmission fluid quite recently. Is there a chance that the mechanic used the wrong type of fluid? IMO, your mileage is quite low to be experiencing this type of problem.
Manual Transmission not Smooth Shifting
