Results 11 to 17 of 17
September 15th, 2015 12:04 PM #11
- Apr 2007
- 40
September 19th, 2015 04:43 PM #12First try to have the clutch adjusted. The mechanic should be able to tell you if sagad na yung adjustment. If your car has done 100K kms, likely na dapat replace clutch disc, pressure plate & release bearing (CPR). Yes, it's suggested that you have all these replaced since if you just replace the clutch disc & pressure plate and not the bearing, after a few thousand kms baka umingay yung release bearing. Baba na naman ng transmission so it becomes more expensive.
- 53,883
September 19th, 2015 05:02 PM #13just with the symptoms you described, it would seem your clutch disks are in need of replacement. what else needs replacement, only upon opening, can they be determined... spring.. disk.. release bearing..
clutch repair is expensive. just opening up the thing already costs a good amount of money. that is why, when it is opened, they recommend replacement of items that might not yet need replacing.. like that clutch release bearing.
often, when opening, the bearing is replaced. period. whatever condition it is in.... because when it fails, the cost of replacement would be thrice the price of the part alone.
in clutch repair, labor sometimes is more expensive than parts.
clutch adjustment?.... i am not sure.. in some cars, the only adjustment that can be done, is the pedal free play. everything else is pre-set in design..Last edited by dr. d; September 19th, 2015 at 05:04 PM.
September 21st, 2015 08:39 AM #14
Well My best bet right now is Goodyear Servitek, they quoted me an amount for the entire clutch replacement
P 5900.00 (Includes the disk, bearings and plates)
P 2500.00 (Labor cost)
Total P8400.00
So question is, do you think this is a pretty good deal, or am I better off going somewhere or searching for the parts myself and just paying for the labor cost?
September 21st, 2015 02:06 PM #15
BANNED BANNED BANNED
- Sep 2015
- 13,917
September 27th, 2015 02:16 AM #16I have a similar problem and the problem tinakas ko yung car. Car ng brother ko. Thankfully wala pa sya dito.
We have a talyer but i cannot bring the car.
Ano cause pag downhill 4th gear biglang bumaba kph and kahit press gas ayaw accelerate and meron noise under parang sumasabit.
Pero thankfully after downhill nung flat road naging ok na accelerate ulit at nawala noise. But hanggang makauwi ako baba ulit kph and noise under car and i need to move the kambyo and ok na naman accelerate and no noise.
Is this a simple repair or big repair.
- Nov 2017
- 9
November 24th, 2017 05:37 PM #17Ganito rin problema ng Getz ko, parang ang hina mag accelerate lalo na pag paatras ano kaya pina repair ni TS.
Tesla Philippines
