Results 1 to 4 of 4
- Jun 2008
- 20
July 24th, 2008 06:59 PM #1Good day sa lahat !!!
Just want to ask some help regarding transmission oil leak (1993 Nissan Sentra), sabi ng tumingin don daw nanggagaling ang leak sa axle oil seal.
Tanong ko lang mga boss kung it is possible to replace that axle oilseal without pulling down the whole tranny ??? o kailangan talagang ibaba ang tranny paara mapalitan yon ??? o baka meron kayong alam na mga sealant na pwedeng mag seal don sa sirang axle oilseal ???
Tanong ko na rin kung saang Shop pwede ipagawa yung leak na yon at mga magkano kaya magiging damage para maayos na yon ???
maraming salamat sa inyo !!!
Hope to hear from you guys !!!
July 24th, 2008 10:28 PM #2
no need to bring down the whole tranny.... replacing oil seal can be done by pulling out axle rod. just buy the oem oil seal plus gear oil kasi for sure may tatapon na gear oil once na tinangal yung sirang oil seal. kung may kakilala ka ng roving mechanics kahit sa bahay kayang gawin yan or any goodyear servitek.... wag lang sa rapide....
July 25th, 2008 03:46 AM #3
You will loose manual transmission oil if leaking.
Remove the wheel and center axle cotter pin and nut take out strut to steering Knuckle bolts (2) pull outward on the knuckle and hold the axle and wigle it out of the wheel bearing spline shaft clear of the knuckle now pry out the inner CV joint toward the out side of the fender it clicks in with a circular snap ring. Now you see the final drive seal pry it out with a screwdriver. Replace it with a new seal.
Also be aware that loose differential bearings can make the new seal leak. Ask your mechanic may have one of those how to things on inner axle seal replacement and have it change that too.
Tsikot Member Rank 5
- Nov 2003
- 3,848
July 27th, 2008 10:13 AM #4just remove the axles, replace the seals and gear oil. do not use sealant for that.
Tesla Philippines
