Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Quote Originally Posted by magsteria View Post
    Ung break pads ko po pala, walang problema. Malakas pa din at walang palya. Nagka leak lang po talaga sa secondary thingy for clutch. Ung primary po kasi, either mag lleak lang kung san mismo nilalagay ang fluid for clutch reservoir or mismong sa ilalim ng clutch pedal. Kung wala pong leak dun at walang pressure ang clutch, malamang nasa secondary thingy. Ill update po siguro tomorrow afternoon kung magkano ang pagawa nung leak. Pero nung dinala ko siya sa mekanino, di naman daw ganun ka lakas ung leak at pwede pa din gamitin pero refil refil lang muna. Bukad pa kasi ako magkaka time para mapaayos, the mechanic estimated it for about 1k. Pero po as for price, update ko po tomorrow.
    Sent from my Flare S5 using Tsikot Forums mobile app
    1K sounds like repair kit and not replace master cylinder.
    we'll find out, when the cylinder is brought down and examined more closely.
    so nag-tapak-bitiw pala tayo! nung gumagawa pa kami nang ganyan, we would choose between wretcher and tapak-er. it was more fun being the guy with the wretch underneath.
    Jun 2018
    mga master,I need help. Im looking for surplus ac compressor for 96corona exsaloon.bumigay na eh.thank you in advance.
    Quote Originally Posted by blackrona View Post
    kung tunay na wala kayong makuha:
    1. rebuild. a local brand can rebuild theirs, daw. it admittedly won't last too long, but it is still better than fan only.
    2. fabricate mounting bracket, for the more common variety of compressor.
    Jul 2013
    ^agree ako sa 2nd option.
    dalhin mo sa aircon shop and paconvert mo na lang to a newer (more modern) compressor
HELP, I'M STRANDED (Toyota Corona 1991)
