Results 1 to 10 of 11
- Aug 2013
- 1
August 20th, 2013 03:40 PM #1Patulong naman po sa Mitsubishi Lancer 2009 GLX
Yung kotse ko di ko mashift yung gear pag binuksan ko na yung makina pero pag nakapatay nalilipat ko naman. Gumagana siya kahapon dumaan ako sa baha at huminto muna sa SM sa amin, nakauwi pa ako sa bahay at ngayong umaga di na bigla ma-shift ang kanyang gears.
Tinignan ko yung clutch fluid okay naman, yung power steering below minimum na kaya nilagyan ko ng power steering fluid. Ayaw pa din magshift. Ayaw ko na mangalikot baka ano pa mangyari kaya nagtanong ako dito. Pudpod na kaya ang clutch ko? Magkano kaya ang aabutin pag pinapalit ko ito?
Salamat sa mga sasagot.
- Sep 2006
- 227
- Apr 2010
- 19
August 21st, 2013 03:25 PM #3Baka kinalawang ang clutch pressure plate at flywheel dumikit ang clutch disc ayaw na ma disengage kaya ayaw mag gear shift. Or baka ang clutch master cylinder mo hindi tumutulak ng tama.
August 21st, 2013 03:45 PM #4
it had been raining lately and you probably drove your car in the flood. the most probable cause is rusted pressure plate and flywheel. try shifting to fourth gear and with the clutch pedal depressed, have the car pushed (nudged) forward and back. this usually releases the clutch disc from the rusted pressure plate and flywheel
- Jul 2010
- 570
August 21st, 2013 07:34 PM #5Nangyari din sa Lancer Itlog ko iyan after lumusong ako sa baha at park sa mataas na lugar. Inilagay ko sa 1st gear kasi inclined yun park sa bangketa.
Nun kunin ko na kotse ay ayaw na shift sa 1st, 2nd, 3rd at 4th. So ang ginawa ko ay off ko muna engine. Taas handbrake. Shift ako ng Reverse at pumasok naman. Then Start yun kotse.
Okay na uli shifting ng kotse. Inabutan pala ng baha yun release bearing kaya na-stuckup.
August 21st, 2013 09:52 PM #6
- 53,883
August 22nd, 2013 05:24 AM #7
August 22nd, 2013 11:43 AM #8
Depends on why this it's stuck.
One of our trucks had trouble shifting after driving it through flood.
Just turn it off, put it in first, start with the clutch fully depressed.
Then every shift afterwards, rev match to make it go in.
After a dozen kilometers or so, it loosened up na.
August 30th, 2013 06:31 PM #9
- Aug 2006
- 728
September 6th, 2013 10:07 AM #10Happened to my Lancer when my wife drove it s flood about almost nakalapat na sa ilalim. The next morning hindi maka shift ng gear..
I made a little research.. and saw somebody suggested here to shift it to 1st or 2nd gear ata.. Press the clutch and start the engine. You will hear a noise after starting the engine.. parang noise na natanggal sa pagkakakapit...
After that nag ok na.. Drive the car a little bit para mag loosen kung ano mang kumapit..
Wala na problem after nun...
Lesson.. as much as possible wag idaan ang kotse sa baha specially pag sobrang lapit n ng tubig sa pang ilalim...
