Results 1 to 3 of 3
- Oct 2013
- 12
October 12th, 2013 01:24 AM #1" Vehicle usually diagnosed with this type of code,has transmission that will not hold in OD/5th gear. It gradually gets worse. Eventually the transmission will not shift back into OD unless you were going down an incline. It will shift out of OD after any sign of load especially after the transmission warms up.
A combination of one and or two would produce a flashing OD light and eventually throw a service engine soon light. Codes returned for the described situation P0775 Pressure Control Solenoid B Circuit Malfunction. Others such as P0732 incorrect gear ratio 2nd gear, P0733 incorrect gear ratio 3rd gear, P0735 incorrect gear ratio 5th gear, are also common.
Vehicle may also experience harsh shutters between shifts (kaldag). "
Has anyone ever experienced having these troubles in your 07 Everest or Trekker??
October 18th, 2013 07:11 PM #2
don't know about Everest and trekker trans, but if it's a 5R55E I think there's a tsb for that. you have to replace the valve body separator plate with laminated gasket and you have to replace the blow-off valve with the new design.f it's not a 5r55e then this tsb may not apply.
- Oct 2013
- 12
October 19th, 2013 01:11 AM #3I agree... but the valve body assembly is different from that of S,N and W's.
Tesla Philippines
