Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Aug 2020
    i replaced the transmission oil of my isuzu mu-x m/t 2017 model with a 15w-40 engine oil and the result was that the shifting from 1st to 2nd gear and from 3rd to 2nd gear became rough. also a noise occurred during morning start-up is observed. the recommended transmission oil for this vehicle per manual is besco transaxle 5w-30. you may also use 5w-30, 10w-30 or 15w-40 engine oil per isuzu mechanic instruction.
    did you experience this?
    I'd follow the oil grade.
    15W40 is for Crosswind MSG5K trans, while axle oil is 85W140
    Quote Originally Posted by waldnerdoe View Post
    i am curious.
    why not stick to the recommended oil grade?
    Aug 2020
    just curious also using thicker engine oil
    Jul 2014
    Hindi ba, usually kapag manual transmission gear oil GL-4, nasa SAE 80, SAE 75W-90, SAE 80W-90, SAE 90?
    Ung GL-5 ng Isuzu, 85W-140.
    Parang malayo ung 15W-40.
    are you really looking at the correct box bro?
    bakit engine oil ang gamit sa transmission? usually mas mataas ang viscosity grade ng transmission oil.
    Same grade yung engine oil sa gear oil sa Isuzu. Transfer, rear, front axle ang nagkaiba.
    Jul 2014
    Oo nga, thanks.
    Ang baba pala ng viscosity ng oil for Isuzu manual transmission.
    Dko pa nabasa ung part na yan sa owners manual, ang kapal kasi. D-Max ang sa amin pero pareho lang yta sa muX.Click image for larger version.
ID:	42002Click image for larger version.
    Sent from my CPH1911 using Tsikot Forums mobile app
    Aug 2020
    Quote Originally Posted by Mask Rider Blac View Post
    Oo nga, thanks.
    Yes sir, 1st gen ba yung dmax mo? 2.5 or 3.0 ang displacement? Yung sa unit ko 2.5 ang dispcement, ang transmission is MUA5H
    Aug 2020
    For 1st gen isuzu mux, pwede engine oil ang ilagay sa m/t ransmission. Ang Sae 90 gear oil ay sobrang lapot compared to 15w-40 oil
rough shifting isuzu mu-x m/t 2017
