Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Jan 2011
    mine is 2007 crosswind xuv a/t... tranny seems to be slipping, medyo mataas na ang rpm, mabagal pa ang takbo.. ang ginawa ko, nagpadialysis atf change hoping mag improve ang takbo.. nakaubos ng 18 liters ng atf at im sure malinis na ang nasa loob at marumi din talaga ang nailabas, parang kulay putik na.. ito ngayon, lumala pa ang takbo after dialysis.. halos di ko na maiuwi sa bahay dahil hirap na pag paahon... sliding talaga.. sa flat roads, makatakbo pa... any suggestions mga sir? sakit na ulo ko dito... magkano kaya rebuilt ng tranny ng crosswind? may surplus kaya pang crosswind?
    Sent from my SM-G610Y using Tapatalk
    Jan 2011
    may naka experience na po ba sa inyo na lumala pagkatapos ng atf dialysis?
    Jul 2006
    I think you need a tranny overhaul.
    As one website would say it:
    When not to flush your transmission
    Before draining or flushing you should pull the dip stick and look at the fluid. If it is dark, burnt smelling, and you see little flakes or speck in it, DO NOT FLUSH IT. The fluid and transmission possibly has hard part damage, but the transmission just has not figured out it should die yet. If you flush a transmission in this condition it could fail right away. Real strange, but that is what seems to happen. If your transmission is in this condition just drive it while you save for a replacement transmission. There is no way of telling when it will fail. It might be today, next week, or next year, but it is doomed.
    The goal here is to flush the transmission BEFORE the fluid gets contaminated. What you are taking out should look like what you are putting in. Do not wait for a color or smell change. Most manufacturers calls for transmission fluid change at 30,000 mile intervals. The industry standard is two years or 24,000 miles whichever comes first. It is your vehicle, you decide what is best for you.
    Jan 2011
    i wish i had read this one!!!! costly lesson to learn....
    Jul 2016
    Ilan na natakbo crosswind mo sir?
    Sent from my SM-J500G using Tsikot Forums mobile app
    Jul 2013
    I'm guessing first time mo mag-overhaul ng transmission mo?
    Unlike manual kasi... Madaming "clutch" sa loob ang AT, kahit anong ingat, mapupud-pod din yan (like manual) and will need a replacement,
    Best is overhaul mo na lang and it will run like new again...
    ^ i agree. once you have it overhauled by a competent shop, it'll run like new once again.
    the cost would probably go as much as 30k - give or take. it's costly, but to put it in perspective, it's just like buying a new set of good quality tires w/o the rims pa - and the newly overhauled tranny will last longer than those rubbers
    my advice, have it serviced at d&r fast auto repair service. they make overhauling trannies look easy at reasonable prices. they even have a flat bed tow truck in case your ride is already incapable of navigating to their shop in paranaque
    pwede din bumili ng surplus pero para sa akin medyo roll of the dice din kasi ang mga iyan. you'll never know in what kind of shape that used tranny you're getting until it's already installed on your vehicle - sugal din eh. so might as well have it overhauled and make use of the 6 months shop warranty (minsan 1 year pa nga ang warranty kung madali kausap ang shop) if you encounter any problems.
    Jan 2011
    thanks sa suggestions sir.. very reputable shop in our area quoted me 28k, parts and labor na..
    Jan 2011
    instead of peace of mind, what I got is a head wracking pressure. I got my transmission rebuild by a neighbor mechanic. I bought the rebuild kit in walco banawe. he's a good mechanic but seems to have done worst for the transmission. ang kupad ng acceleration pagkatapos ng rebuild. walang arangkada sa paahon. bayad utang kasi ang labor niya, pinatulan ko nalang para quits na sana. parang nalugi pa tuloy ako nito. any possibilities po kung anong nangyari? ayaw ko na rin siya ka usapin, patingnan ko nalang siguro sa iba.
    Bring your vehicle to an Isuzu dealer. They may be ablento help you.
    Sent from my SM-G920F using Tsikot Forums mobile app
Crosswind a/t slipping
