Results 1 to 10 of 23
- Jan 2011
- 262
March 24th, 2011 01:56 PM #1Hi guys, I'm just a new driver and I have read about the adverse effects of riding the clutch. Anyway, my question is this :
1. Is it ok to step on the clutch pedal while braking when decelarating?
2. Is it ok to step on the clutch pedal IF you're not stepping on the gas pedal?
TIA Veteran Drivers!!!
- Jul 2009
- 3,604
March 24th, 2011 02:26 PM #2Di ako super veteran driver, but:
1. It's probably better to step on the clutch pedal when your RPM is nearing under 1000. Engine braking helps further slow your car down and puts less wear on the brakes.
2. Is this at a stop? If so, ok lang naman but if you're at a stop, might as well put the car in neutral.
I read somewhere that the clutch should either be depressed fully or not at all for maximum clutch longevity. Keeping the clutch pedal anywhere in between for more than a small amount of time (or "riding" the clutch) isn't such a good practice yata.
- Jan 2011
- 262
March 24th, 2011 02:42 PM #3
- Jul 2009
- 3,604
March 24th, 2011 02:47 PM #4If the clutch pedal is fully depressed, then I'd think hindi.
Try to make it a habit to only use the clutch pedal when you need to.
Di ka rin naman masasanay if you don't start now.
March 24th, 2011 02:56 PM #5
sabi use the clutch to change gears lang.. pag mag brake ka.. tapak lang sa preno.. pag mamatay na yung makina.. or mababa rpm.. clutch, gear to neutral..
- Jan 2011
- 262
March 24th, 2011 03:34 PM #6
March 24th, 2011 03:52 PM #7
Learn more about clutches so you get to know the principle behind stepping and letting go of clutches.
http://auto.howstuffworks.com/clutch.htm
- Jan 2011
- 262
March 25th, 2011 12:54 AM #8Sirs how about in a stop and go traffic scenario? Is it ok to step on the clutch pedal at low speeds?
- 172
March 26th, 2011 09:20 AM #9
Tesla Philippines
