Results 71 to 80 of 370
June 15th, 2013 07:27 PM #71
June 15th, 2013 07:31 PM #72
actually sir sa phone lang ako nag inquire about their dialysis process... yung color ng ATF ko is currently light brown sa paper towel pero wala namang burned smell. kaya gusto ko na din palitan lahat ng fluid.
sa servitek marcos hi way may dialysis daw sila pero i haven't seen kung meron talaga silang transtech...
June 15th, 2013 07:53 PM #73
Imho servitek (mostly) may teanstech machine na. Sa cavite aling aguinaldo hiway meron na eh.
Sent from my GT-I9300 using Tapatalk 4 Beta
June 15th, 2013 08:31 PM #74
sige thanks sir... will try and visit servitek sa aguinaldo. sa dasma yun diba?
June 15th, 2013 08:52 PM #75
Imus pa un sir, near imus medical center
June 15th, 2013 09:52 PM #76
sige sir bisitahin ko na lang sila... magdadala lang ako ng sarili kong ATF. thanks!
- Jan 2010
- 28
July 15th, 2013 05:34 PM #77
July 29th, 2013 03:39 PM #79
Question about the dialysis style. Do we need to use the actual fluid during the "clean and drain" process? I just called one of the shop on the banawe and as per sales guy, they have regular fluid (much cheaper) for cleaning and you will use only the actual fluid for final process. Is this true? Or should we use the actual fluid for the whole process of dialysis? Thanks!
July 29th, 2013 03:50 PM #80
In my case we used the actual fluid but this was just regular ATF. I guess if your ATF is really dirty and you plan to put a designer fluid, it should be okay to flush first using a cheaper ATF then you start cycling with the more expensive one as the system clears up.
