Page 1 of 2 12 LastLast
Results 1 to 10 of 370
    Jul 2010
    how about the process of AT dialysis? nakakailan friends na nakapagsabi na maganda daw yung process at hindi magasto kasi normal ATF qty lang kelangan
    saan area nyo sir? sa east side meron sa alpha performance along gil fernando ave in marikina
    sa quezon city area meron sa fronte ata yun sa banawe/kabignayan st
    Jul 2010
    Yup sa fronte sa banawe meron, dito sa shell station along gov drive malapit GMA Cavite meron
    complete atf flushing? shops with ATF transfer machine will be the best place you should go but if you are on a tight budget, you can DIY also...
    all you need is a good helper, a funnel and your guts to do it....
    Aug 2003
    just did this sa starex AT ko last month, umabot ako ng 2.5k kasama na dito ang 12L of total ATF at labor, mas mura sa EXALTA banawe kaysa sa fronte, sa exalta pwede ikaw magdala ng ATF mo at P600 lang babayaran mo sa machine
    Will be having the ATF dialysis done at Exalta tomorrow. I hope it works.
    San ba ok bumili ng ATF?
    Nov 2011
    ano po ang pinamurang ATF? brand?
    ang binili ko po ay Perrari / Ferrai (local) D III... nasa 150/liter.
    baka meron pa kayong alam na mas mura at saan po?
    Apr 2010
    Quote Originally Posted by dbdrag View Post
    Sir, anong ATF brand ito and saan nyo binili yung ATF? thanks!
    Jun 2012
    hi plano ko sana magpa dialysis sa exalta ngayon, tanong ko lang po sana kung maayos kaya yung jerk or thud pagpasok ng second gear?
    may nakaexperience na ba sainyo nito?
    nissan exalta grandeur po pala unit ko.
    thanks!
    Apr 2010
    Quote Originally Posted by phezthie View Post
    yes diy is good. there is part also that the rubberized hose going to the transmission pipe is so tight that my mechanic is having a hard time removing it so that the transmission fluid will go directly to the Dialysis Machine > Radiator line > then back to Transmission.
    and also yun pressure ng transmission. there is part din you need to shift all the way to L (P-R-N-D-2-L) para lumabas lahat ng old fluid.
Changing ATF Fluid completely (DIALYSIS PROCESS)
