Results 1 to 5 of 5
- Oct 2009
- 179
June 20th, 2014 02:29 PM #1Help, hirap po magshift sa 1st gear from stop or downshifting pag sumasabit parang nagkakaskasan na gear, kailangan ko pa diin na sagad na sagad pagka depress ng pedal bago ko maishift sa 1st gear.
Hindi naman sliding, hindi naman matigas tapakan, mahirap lang talaga ishift from neutral to first gear or pag mag dodownshift ako. Parang kailangan ko tangalin un carpet para madepress ko ng maayos para maishift un kambyo. Kailangan lang ba ng adjustment nito?
Thanks.
June 20th, 2014 03:03 PM #2
If your car has clutch cable, it might need adjustment to compensate for wear. Or check your transaxle lube for quantity and condition. Idle speed is also a factor.
Nakiki wi-fi lang
- Oct 2009
- 179
June 20th, 2014 03:16 PM #3
June 20th, 2014 03:20 PM #4
Adjust to lengthen the cable slightly to give a slack and secure your adjustment
Nakiki wi-fi lang
- Oct 2009
- 179
