Results 1 to 7 of 7
- Nov 2014
- 454
August 8th, 2015 12:35 AM #1Pwede ba kahit any type na DOT3 pang top-up ng brake at clutch fluid? Last November lang yung Ertiga namin, ok naman brakes pero parang hindi lang ako comfy sa gear stick mismo. Usual ba yung me tunog na parang toggle o alam mong kumakagat yung ngipin every up/downshift? Then pag reverse medyo malakas lalo pag nasa labas ka. Mababa lang naman ng unti sa max level yung fluid. Baka lang mag-improve hehe.
Sabi ng contact namin sa Suzuki Sucal service eh normal daw yon, pinarinig ko sa kanya kahapon thru phone.
TIA
August 8th, 2015 01:20 AM #2
Yep basta kung ano naka sulat sa filler cap ng fluid (DOT3/DOT4) kahit ano brand pwede.
If sa gear stick, baka need ng adjustment ng clutch pedal, kumbaga parang may sabit yun pakiramdam mo ba?
Or pwede mo muna try sagad yun tapak nun clutch pedal baka hinde lang nasasagad or minsan need ng konting bomba.
OK rin ba level nun transmission oil?
- Nov 2014
- 454
August 8th, 2015 07:43 AM #3Salamat midnytwarrior.
Oo eh, pakiramdam ko sumasabit, feeling ko normal kaya lang minsan malakas. Sinabi ko na yon last month nung PMS namin kaya in-adjust nya na yung clutch. Cge try ko na lang muna bombahin, mkikita din ba yung transmission oil indicator sa hood?
No need naman i-drain o tanggalin yung brake fluid ngayon, top up lang ok na?
Salamat ulit
August 8th, 2015 08:54 AM #4
Your welcome.
Na adjust na pala yun clutch. Since last November lang yun auto mo so halos brand new pa.
Brake fluid naman hinde naman agad i top-up yan unless may tagas o leakage.
Pag mabilis sya mag bawas, possible may leakage. Hinde all the time dinadagdagan. Once bumaba na after some given time, need i check yun brake pads sa unahan since baka manipis na kaya umurong na yun brake fluid. Pagka alam ko drums kasi yun rear brakes ng ertiga at need ng manual adjustment.
Regarding sa clutch fluid naman, meron mga naka separate at meron naman share ang reservoir sa brake. Hindi ako sure sa Ertiga kung shared o separate.
Need palitan kung marumi na yun fluid. Sa akin two years old na at 73,000KMs na pero hinde ko pa pinalitan yun fluid at makikita sa reservoir na clear pa rin.
Try mo pag clutch is halfway sa unang tapak, balik pataas then sagad na tapak bago pasok ng kambyo.
Your welcome.
- Nov 2014
- 454
August 8th, 2015 04:55 PM #5Ni check ko yung indicator sa manual at part ng engine yung para sa transmission oik. Me nakita ako ende lang ako sure, ask ko na lang yung pinsan ni misis taga toyota service center, baka kung anu pa mahugot ko. shared yung reservoir ng brake at clutch fluid at ala namang leakage kasi unti pa nabawas
Maraming salamat sa mga inputs :-)
September 1st, 2015 07:34 AM #6
Tanong ko lang sir, kung okay lang ba bumili sa mga ace hardware sa SM? Mas mahal ba ang presyo ng mga brake fluid kapag sa SM?
- Apr 2018
- 15
May 2nd, 2018 06:20 AM #7
Pa-help naman po, naexperience ko po kasi na hinde ako maka-shift ng gear kapag naka turn on yung engine. Pero pag naka turn off naman po, nakaka shift ako sa kahit anong gear. And i noticed po na biglang malambot apakan yung clutch ko, parang wala ako inaapakan. i checked on the clutch fluid sa may engine, wala ng laman.
Ano po bang fluid pwede ko gamitin? wala din naman pong signs ng leak sa may engine. Ano po kaya problem ng FD ko? and baka meron po kayo ma-suggest na reliable mechanic, makati area po sana.
Honda Civic 06 1.8S Manual po pala yung ride ko.
Salamat po mga ka-tsikoters.
Tesla Philippines
