Good day.. im also having the same problem with my 2005 altis.. can you give me a trusted shop regarding this matter.. thanks!!
Quote Originally Posted by miko101130 View Post
dalin mu sa automatic transmission specialist.. i know someone if your interested... this is a flow of what to check,
1.ATF ("correct specification" and amount) too much and too little is bad
2.Electrical system of the vehicle especially the transmission (wiring, baka me loose connection or kulang sa ground etc.)
3.mechanical portion ( shift lever baka stuck up/ cable going to tranny baka naiipit or meh nakaharang)
after nyan at nandyan pa din problem, do a fault code scan ( code scanner OBD/ on board diagnostic)
from that malalaman mo na kung anu error,, pag wala makita sa OBD( there are times na meh problem but not detected)
4. transmission body check ( titignan na yung internals ng transmission mo including yung solenoid which controls the amount of ATF fluid to maintain hydraulic pressure. medyo madugo na ito at mahal
just a note ilang kms na ang altis?
and how hard is the altis being driven?
nabaha ba unit?
ilang beses ka na nag ATF change since nakuha mo unit?
ATF change should be performed at 40,000kms
