Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 68
    Quote Originally Posted by alwayz_yummy View Post
    hanging burn out you clutch and wastes fuel.. not to mention premature wear-and-tears...
    kaya handbrake nalang kayo bago umabante sa incline.
    edit: mas madali pang mag-handbrake than mag-hanging noh!
    tama, saka nakakangalay din un. kung aapakan mo naman brake kelangan mabilis reflexes mo. hehehe. dati ako ganon pero nung nagtagal handbrake na lang. tapos ang problema
  2. #12
    bad naman talaga ang "hanging" that suicide! hehehehe
    and if i may add, wag kang tututok sa nasa harap mo. kasi kahit yong experienced drivers minsan hindi maiwasang mamatayan o mapaatras.
    May 2007
    Quote Originally Posted by karlo4real View Post
    bro pareho tyo bago lang ako natuto mag manual.. ang gina gawa ko may bitting point ung sa clutch isakto mo dun tpos bitaw sa break sabay apak dahan dahan sa gas... naka primera ka nun ah.. at wag na wag ka kakabahan ako kasi dati kabado ako kaya umiiyak ung gulong ko pag aabante sa takot na mamatayan or may maatrasan.. minsan amoy clutch ako hehehe.. pero okay lang yan napapalitan naman yang sira.. mag practice ka lang..
    Quote Originally Posted by badbadtz.carlo View Post
    if nde mo pa masyado gamay ang car and nde mo pa timpla ung timing ng release ng brake then apply gas, i suggest use what i usually do then.
    Hand Brake Abuse!
    everytime titigil, especially if traffic sa mga flyovers, handbrake then Neutral lang. then when ready to go, depress clutch,ready the gas, then release handbrake + apply gas.. then repeat as needed. this way, safe ako na walang rear damage to my car, and hassle sa mga nasa likod ko..
    then practice lang pag weekends sa pagtitiming..
    HTH
    Quote Originally Posted by flakez View Post
    [SIZE=4]Guys, just a reminder: [/SIZE]
    [SIZE=4]Please be more conscious and cautious with the way you type your sentences. Review your "replies to threads" before posting![/SIZE]
    [SIZE=4]"TEXT LANGUAGE" is not allowed in our TSIKOT FORUMS.[/SIZE]
    [SIZE=4]Maraming salamat po. [/SIZE]
    sa akin naman maghanap ka ng naka incline na road na hindi masyado practice lang 1 to 2 hours bumitin di mo na malilimutan yung skill mo dun, natuto kasi ako sa jeep walang hand brake kaya napilitan akong matutunan laruin yung clutch and gas pedal, mas ideal yung hand brake but its nice to learn that skill too
    Quote Originally Posted by LHV View Post
    Agree that it is nice to learn that skill (clutch and gas pedal thing). However, kindly bear in mind that there is an unnecessary strain and abnormal wear and tear on the clutch every time you do this....
    7303:soda:
    practice lang to gain confidence and depende again. kung alam mong matagalan use your handbreak pero kung moving naman might as well use the other option which is timplahan .
    buti na lang automatic binili ko....
    kaya bilib ako sa mga jeep driver dito sa Baguio para bang nasa flat roads lang sila kung mag-maniobra kahit medyo steep ang gradient ng mga roads minsan... ser mukhang nakalimutan mo yata yung apak sa preno sa iyong kumbinasyon
  10. #20
    Quote Originally Posted by sum1_27 View Post
    well, if you leave the lever to D while on incline/steeped on the brakes, you'll burnout the clutch on the 1st gear..
    YES each planetary gear of the AT has its own clutch(from P to overdrive-OD/D4/D5, including N)! so, dont ask why your AT is slipping in the future..id say after a year(if you continue that practice)
    ganun ba talaga kahirap "to put in to neutral and pull the hand brake"?
hanging - best practices
