Results 581 to 590 of 1444
- Aug 2012
- 2,767
April 4th, 2014 09:38 AM #583^recommended upsizing is maximum +/- 2% difference in circumference. assuming you have stock 195/65R15..
changing to 205/50R17 results in +0.36% difference in circumference..
- when speedometer reads 100 kph, you are actually travelling at 100.36 kph.
- when trip meter reads 1000 km, you actually traveled 1003.6 km
changing to 205/45R17 results in -2.78% difference in circumference..
- when speedometer reads 100 kph, you are actually travelling at 97.22 kph.
- when trip meter reads 1000 km, you actually traveled 972.2 km
so 205/50R17 would be fine. you just need to do an actual fitting to check the offset..
pag masyado negative offset, tatama ung rim sa upper arm ng suspension. pag sobra positive offset naman, lalabas ung gulong, kapag umulan, puro putik yung tabi ng body.
things to note:
- changing to bigger rims results in higher fuel consumption and slower acceleration.. bigger rims are heavier.
- using low profile tires means less rubber (short sidewall height) which makes a harder ride (less cushioning). you may need to compensate with softer shock absorbers.Last edited by red_one; April 4th, 2014 at 10:16 AM.
- Jun 2008
- 19
April 8th, 2014 07:52 PM #585Ask ko lang po mga sirs saan ba makakabili ng mga genuine toyota revo parts para sa pag overhaul ng engine dito sa manila.tnx po.
Posted via Tsikot Mobile App
- Apr 2011
- 588
- Apr 2014
- 1
April 11th, 2014 11:21 PM #587Hello!
I need a replacement for my revo's alternator. Has anybody used the Unipoint brand? If yes, how was it? How long did it last? Is it any better than Ishin Denki? Any other brand that you know of? Your thoughts will be appreciated, thanks!
Revo details: 2003 GSX 2.0L gas engine (1RZ)
- Feb 2011
- 17
April 15th, 2014 11:27 AM #588Hi,
Tanung ko lang po kung san nakakabili ng mura na alarm casing ng 2002 revo. Nabasag na po kasi yung amin (pati yung spare) at nakatape nalang.at may nabibilhan pa po ba ng quad headlamp? Balak ko po kasi palitan yung amin kasi pina convert ko ng h.i.d. Si revo, kaso mahilig ako mag flash ng high beam pag umaga eh, ang tagal kasi bumuga pag sa hid. Pati po ba pag humihina yung power, ibig sabihin kailangan na i-calibrate yung injectors? Nabasa ko po kasi sa ibang forums (different diesel vehicles) na kadalasan yung solusyon pag humina ang power. Thanks sa mga magrereply po!
- Feb 2011
- 17
April 15th, 2014 11:30 AM #589Hi,
May mga questions po ulit ako:
1. Tanung ko lang po kung san nakakabili ng mura na alarm casing ng 2002 revo. Nabasag na po kasi yung amin (pati yung spare) at nakatape nalang.
2. at may nabibilhan pa po ba ng quad headlamp? Balak ko po kasi palitan yung amin kasi pina convert ko ng h.i.d. Si revo, kaso mahilig ako mag flash ng high beam pag umaga eh, ang tagal kasi bumuga pag sa hid.
3. Pati po ba pag humihina yung power, ibig sabihin kailangan na i-calibrate yung injectors(diesel po sa amin)? Nabasa ko po kasi sa ibang forums (different diesel vehicles) na kadalasan yung solusyon pag humina ang power.
- Feb 2011
- 17
April 15th, 2014 11:31 AM #590Sorry double post. Nagerror po yung sa unang post ko eh, akala ko hindi malalagay.
Tesla Philippines
